  • Guests: 41
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
** Add your Tesla coil here **
GreenLab
Wed May 11 2011, 11:18PM
GreenLab Registered Member #3047 Joined: Thu Jul 29 2010, 10:56PM
hello,
here is my new over head tesla coil. I built it for a theatre in germany.
spark pics follow...
Img0501b Img0500bs
EDIT:
Final version
Img0656s 34598033
greets, GreenLab
Dieu
Mon May 16 2011, 11:46PM
Dieu Registered Member #1730 Joined: Thu Oct 02 2008, 08:12AM
Hello
Here are my SSTC, full bridge, resonance frequency- 117kHz without torus, spark length 20-25cm(10inch), capacitor-5uF/800V Rifa, antenna feedback, full bridge on FGA25N120ANTD igbt, fake safety ring is antenna :)
I hope it somehow looks like Dr spark project.
1305589569 1730 FT14 Dsc00382
1305589569 1730 FT14 Dsc00373
1305589569 1730 FT14 Dsc00377
hsieh
Sun May 29 2011, 02:43PM
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
Portable demonstration tesla coil
Steve SSTC 5 schematic
500 turns secondary
resonant frequency 500KHZ
20N60A4 half bridge
5cm spark@110V AC input
GDT:EE16 EE ferrite core
secondary CT feedback
1306680171 1412 FT14 Dscn8172
1306680171 1412 FT14 Dscn8174
Fri Jul 22 2011, 11:55AM
Kaizer DRSSTC I
Thread: Link2
All information and schematics etc: Link2
Specifications
Resonant frequency
Around 70 KHz
Secondary
160 mm diameter x 605 mm height , 2200 turns of 0.25 mm enamelled wire
Topload
630 diameter x 130 mm ducting diameter, dryer ducting, this is subject to change
Primary
320 mm diameter x 150 mm height, 9 turns of 10 mm copper piping ~ 28,27 mm^2, tapped at 5.5
Bridge
Fullbridge of IXGN60N60C2D1 IGBTs, SOT-227 package
150 mm length x 80 mm width x 90 mm height, 1 KG of heatsink
2 x 3300uF 450V BHC capacitors for 6600uF bridge filtering. (each: ESR 39mOhm@100Hz, Z 27mOhm@10kHz and 53A Iripple@70KHz@50 Degrees celcius)
MMC
6 Strings of 2, 942C20P15K-F
0.45 uF rated 4000 V and 81 A Irms
1287308843 1403 FT1630 Img 1884
1289074645 1403 FT1630 Img 2669
1289074645 1403 FT1630 Img 2833
climatex
Mon Aug 15 2011, 12:42AM
climatex Registered Member #2012 Joined: Sat Mar 07 2009, 10:22AM
My first tesla coil ever, it's a micro table-top VTTC.
Fcl8ug
Inspiration by Dr. Kilovolt.
Tube used is RFT PL 500; heater switchable on the fly between 27 and 30V.
Two-stage mains multiplier as the anode supply.
Possible to switch between quasi constant-wave and thyristor (SCR) cathode interrupter mode.
Fused mains supply (3A F) + cathode (315mA F).
Primary 16 turns, feedback 10, secondary >1100 (0.09mm wire). The secondary is 10cm tall on a diameter of 5 cm.
Resonant cap 2x paralleled WIMA FKP 1n5 1250V=
QCW mode dual 3.5-4cm streamers; 4.5 to ground; with a good breakout point, one 4.5cm free-to-air appears (pictured). Interrupter 6-7cm streamers both free-to-air and ground.
281vwo1
QCW with breakout point properly set.
Kcjcsi
Cathode interrupter.
Best regards climatex
MRacerxdl
Wed Aug 31 2011, 07:35PM
My first *goodworkingdrsstc* - I'm really proud of it, and I called it ZARC DRSSTC:
Specs:
Secondary: 45x15 cm with 30AWG Wire (60cm total height of secondary)
Fres: 90kHz
MMC Bank: 117,5nF 3200V (5x2 of 47nF 1600V)
Primary Peak Current: About 250A running without OCD
Fullbridge of IRG4PC50UD running at 320VDC Bus
About 1.2 meter sparks :O
Audio Modulated :D
5583128683 Bdaf08de1a M
5578227187 52ea8e2c1e M
5783525725 C161503921 M
Videos:
Extreme Electronics
Tue Sept 20 2011, 08:23PM
Extreme Electronics Registered Member #74 Joined: Thu Feb 09 2006, 09:17AM
Haven't posted for a while, though Id update with my latest coil a Steampunked SSTC "The Aetheriser"
1316549679 74 FT14 Theaetheriser
SSTC Control, Micro processor, Bluttooth remote, bridge, Etc..
1316549679 74 FT14 Img20110602 960 Sm
Aetherising... & illuminations...
1316549679 74 FT14 Aetherising
Topload Detail
1316549679 74 FT14 Topload
More Steampunked coil detail at www.aetheriser.co.uk
More Real Details at www.aetheriser.co.uk/index.php?page=real
Tue Oct 25 2011, 01:51PM
Kaizer DRSSTC II
Full article with all pictures, construction etc: Link2
Bridge
2x IXGN60N60C2D1 IGBTs in a half bridge configuration
Bridge supply
0 – 210VAC through a variac, 6A rectifier bridge and 2x Aerovox 410uF 430V filtering capacitors in parallel.
Primary coil
Flat primary. Inner diameter 70 mm, Outer diameter 187,36 mm. 6 turns 1,78 mm copper wire (2,5 mm²), turn spacing 8 mm. Tapped at 4.8 turns.
MMC
2 in series Cornell Dubilier (CDE) 942C20P15K-F capacitors for 0.075uF at 4000VDC rating.
Secondary coil
50 mm diameter, 200 mm long, 1430 windings, 0,127 mm enamelled copper wire.
Resonant frequency
Around 327 kHz.
Topload
40 x 215 mm aluminium tape on a Styrofoam toroid.
Input power
350BPS, 120uS ontime, 35 primary cycles, 280A limiter: 210 VAC in at 2A. 420 Watt.
Spark length
Up to 370 mm long sparks.
1319550707 1403 FT14 Img 5164
1319550707 1403 FT14 Kaizer Drsstc2 2011 09 16
Cain
Wed Nov 02 2011, 01:19PM
Cain Registered Member #624 Joined: Tue Apr 03 2007, 07:50AM
a short vid of my dual MOT ASRG coil 6" secondary
+medium
zzz_julian_zzz
Fri Jan 06 2012, 01:54AM
ADD COIL: PHILIPPINE DRSSTC
SPECS:
spark: 35 inches (MAX)
fres: ~200khz
bridge: Full/ IRG4PF50W / D
primary: 6t #10awg (6 inch O.D.)
tank cap: 75nf / 4kV DC
coupling: .15
secondary: 1200t #32awg (10 inch x 4 inch O.D.)
toroid: 13 inch x 2.2 inch (larger)// 8inch 2.5 inch(smaller)
filter cap: 4000uf / 350vDC
power in: <500 watts
driver: Discrete driver/ with logic and primary feeded// w/o OCD & synchronizer
interrupter: Basic (20 - 200 bps/ 50 us - max on time)
GDT: black/ unknown specs & material
PLEASE WATCH THE VIDEO
1325814889 3964 FT14 6 Turns Primary Coil
1325814889 3964 FT14 10 Inch Secondary Coil
1325814889 3964 FT14 Cooling Fan
1325814889 3964 FT14 Driver Board
1325814889 3964 FT14 Filter Capacitor
1325814889 3964 FT14 Full Bridge
1325814889 3964 FT14 Gdt
1325814889 3964 FT14 Interrupter
1325814889 3964 FT14 Topload
