  • Guests: 37
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
** Add your Tesla coil here **
Florian
Fri Nov 28 2008, 07:55PM
Florian Registered Member #1827 Joined: Fri Nov 28 2008, 07:05PM
6inch SG-Coil
Secondary: 1200 turns 0,6mm enamelled copper wire on 650mm
Transformer: dual Neon 12KV@150-300mA
Max. Sparks to ground: 1300mm (2x WL) -> No finished yet
Tank cap: 30nF@18,75KV WIMA MMC
Sparkgap: Stativ vacuum-singlegap
Th
Img04th
gangster
Mon Dec 29 2008, 11:56PM
gangster Registered Member #1831 Joined: Sun Nov 30 2008, 03:09PM
This is my mini VTTC with 6P45S tube
Parameters: - secondary coil 5x14,5cm , cca 700 turns
- primary coil 7,5cm diameter 20 turns
- feedback coil 18 turns on 7,5cm diameter
- power supply 1MOT with triac regulator
- max sparks of this coil - 25cm
1230594990 1831 FT14 Ivttc1
1230594990 1831 FT14 Minivttc3
1230594990 1831 FT14 Ivttc9
1230594990 1831 FT14 Ivttc6
Sat Jan 24 2009, 11:38AM
Tubes 2x RCA 811A transmitter tubes
High voltage supply 2300VAC MOT with voltage doubler. Supplied with 150Vac through a variac.
Primary coil 180mm diameter, 1.78mm diameter copper wire, 26 windings, tapped at 22 windings.
Capacitor tank 4nF doorknob Fribourg capacitor 20kV pulse rated
Secondary coil 75mm diameter, 440mm long, 1600 windings, 0.25mm enamelled copper wire.
Topload 45mm small diameter, 152mm large diameter John Freud toroid
Gridleak circuit 19 windings feedbackcoil, 1nF capacitor and 500R to 2K5 resistor.
Input power 300W at 150V input voltage, 900W at 180V. 50W for the tubes heating.
Spark length up to 330mm long sparks.
You can see all the rest of the picture and construction notes here: Link2
Sonic
Sat Jan 24 2009, 11:03PM
Sonic Registered Member #1932 Joined: Sat Jan 24 2009, 10:50PM
Hi, my first post.
Last 6 months I've been working in my spare time on my first coil. I've taken lots of pictures of the construction, which may be helpful for other coilers. The pictures can be found at: http://www.flickr.com/photos/sitelab/sets/72157605931875044/
Your comments are welcome.
1232838159 1932 FT14 Img 3042 400
update 090505:
The coil is powered by an NST of 12kV/16mA. The coil has 10 primary windings and 900 windings on the secondary coil. It has been tested now with 2 different designed static spark gaps.
Static gap 1:
3222947047 3a3ac6390a
Static gap 2:
3242662042 69cb991b18
The result however was a bit disappointing. A movie can be found here:
http://www.flickr.com/photos/sitelab/3230823415/in/set-72157617656624468/
I have just finished a Synchronized rotary spark gap, which I will test this week.
This is a picture of the finished SRSG:
3494374091 364670e1bf
I am very curious about whether this will bring bigger sparks. I'll update this post once I have been able to test it.
Duality
Sun Feb 01 2009, 03:04PM
Duality Registered Member #1951 Joined: Sun Feb 01 2009, 01:59PM
can i add my tesla too?
i don't have a pic but a movie of it angry
its primairy is 18 turns.
is secundary is 450 turns. and 18cm high.
its diameter is 2,5 cm.
powered by a flyback driven by ne555 :P
i am pumping 29 volts treu it.
i dont know how many amps.
in case of the sstc same set-up only no flyback,
and no caps (big ones i don't know the values )
and no spark gap (spark gap is adjustable)
20 to 200 mhz running i don't know where it is exactly.
(still work in progress )
arc length 3 cm frown
edit:
it's now a sstc ;)
edit:
and now it's a spark gap again ;)
MRacerxdl
Sun Mar 01 2009, 11:45PM
Hmm, posting here my new DRSSTC
Halfbridge of STGW30NC60W running at 300VDC
3800uF 400V Cap Bank for DC Smooth.
47nF 6400V Primary cap.
65cm height x 10cm diameter wounded with wire 30AWG
140kHz Fres (Still needing a bigger topload)
35-45cm sparks to air, and safe ground striks :D without OCD.
Video: Link2
1235951088 989 FT14 Dsc08518
1235951088 989 FT14 Dsc08489
kilovolt
Sat Mar 14 2009, 08:11PM
My VTTC, built about one year ago. The tube is a Russian GU81M Pentode.
Vttc
Vttc2
Power transformers are 2 pcs 10kV potential transformers, limited to about 3.5kV AC. No level shifter used.
Regards kilovolt
Alexandre
Mon Mar 16 2009, 05:42PM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
My SGTC, built in a weekend that I had nothing to do tongue
Secondary - 4inch PVC tube 40cm 24AWG wire
Primary - 13 turns 5mm tube (tap on 6º turn)
RSG - 3450 assyn. motor, 20cm acrylic disc 12 contacts
Power - QUAD-MOT power supply aprox. 5KW
Cap bank - series of 30 capacitors, 1uF 630V each, total 33nF@ 19kv
Toroids - mini toroid, 6cmX25cm - bigger toroid 13cmX40cm
1 meter sparks to the air amazed
Pictures:
1237224921 1228 FT14 Pict0192
1237224921 1228 FT14 Pict0193
1237224921 1228 FT14 Pict0194
1237224921 1228 FT14 Pict0195
video in HD shades
ElectricalEngg.
Wed Apr 29 2009, 06:32PM
ElectricalEngg. Registered Member #1946 Joined: Sat Jan 31 2009, 11:37AM
My Tesla Coil Configuration:
Primary Transformer Output Voltage (VAC) 6000.0000
Primary Transformer Rated Current (AMP) 0.0300
Primary Transformer Input Frequency (HZ) 50.0000
Primary Transformer Input Voltage (VAC) 220.0000
Primary Transformer PFC Rating (%) 100.0000
Primary Coil Inside Diameter (IN) 3.0000
Primary Coil Wire Diameter (IN) 0.1760
Primary Coil Wire Spacing (IN) 1.0000
Primary Coil Number of Turns 10.0000
Primary Coil Angle From Horizontal Plane (DEGREES) 0.0000
Primary Coil Calculations
Inductance (mH) 0.0289
Average Radius (IN) 7.38
Total Diameter (IN) 26.52
Wire Length (FT) 36.02
Secondary Frequency (kHZ) 230.4926
Primary Capacitor Required (uF) 0.0165
Secondary Wire Diameter (IN) 0.0126
Secondary Coil Total Outside Diameter (IN) 2.0000
Length of Secondary Coil (IN) 26.0000
Secondary Wire Gauge 28.0000
Secondary Turns/Inch 75.1582
Inductance (mH) 13.36
Medhurst K 1.62
Radius (IN) 1.00
Circumference (IN) 6.28
Wire Length (FT) 992.48
Self-Capacitance (pF) 8.25
Secondary Frequency (kHZ) 479.41
Secondary Frequency W/Terminal C (kHZ) 230.49
Top Load Capacitance (PF) 27.4459
Sphere Radius/Toroid Tube Diameter (IN) 3.5000
Toroid Diameter Tube Center-to-Center (IN) 26.0000
5nm0oh5mc6gkxkfntu09 Thumb
Qb2y67vr9fu7awybi23g Thumb
4istsjqyfkq6m2kvky Thumb
My Tesla Coil a few details and better sparks view :)
http://www.youtube.com/watch?v=z5upzouQxcA
jeffomatic
Sun May 03 2009, 07:46AM
jeffomatic Registered Member #2106 Joined: Sun May 03 2009, 07:26AM
Hello! New coiler here.. 59 year old Utahn. The first one I built was back in 1967 and wasn't very successful! My new SGTC has just been built. It uses a 12 KV 60 MA NST and a Maxwell .025 UF 50 KV pulse cap.
I wound the secondary on plastic pipe with litz wire. It has a top section of smaller diameter. Using a simple spark gap, I got good 20 inch streamers with minimal tuning. I used the classic tesla java calculator to good advantage. I'm using a rather steep conical primary of 1/4" copper tubing. The torus top load is a foil tape covered foam water toy section, then burnished with a spoon. It was a lash up on the bench. When first powered, the coil sought out a bicycle that I have hanging from the ceiling, with streamers shooting from the bike to the wall. Now I am installing it on a retro lamp table with proper safety considerations, such as a strike rail, Acrylic shields around the primary parts, etc. It's lots of fun, and I'm looking forward to getting some good pictures of various discharges.
I also have a half-built VanDeGraaf that I hope to complete soon.
1241336226 2106 FT14 Sparks06
1241336226 2106 FT14 Sparks04
1241336226 2106 FT14 Table
