  • Guests: 35
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
** Add your Tesla coil here **
MRacerxdl
Wed Sept 10 2008, 10:02PM
Here is my first good drsstc.
Half-bridge of stgw30nc60wd (60A 600V), running at 127VAC Mains with doubler (~300VDC Bus)
Primary Cap 50nF 1600V (I know it should be bigger voltage)
I didnt make any protections so far, but I when I try the fullbridge design I will put some TVS and a Current protection.
Here are some pics:
My H-Bridge (Wire-mess, but it works :D) and the sparks (~50cm to the air)
Interrupter runs from 50BPS to 600BPS (2,5A to 10A)
Fres = 244kHz (Measured)
1221084084 989 FT14 Dsc04838
1221084084 989 FT14 Dsc04827
And a video:
Steve Hobley
Thu Oct 02 2008, 02:46PM
Steve Hobley Registered Member #1731 Joined: Thu Oct 02 2008, 02:22PM
Here's mine - a 60ma 12kv NST.
Mainly built with parts from Alan Majernik's Teslastuff site.
1222958692 1731 FT14 Smooth1w
Here's a youtube clip of it running (with nasty flashover from primary to strike rail at the end suprised )
http://www.youtube.com/watch?v=GO9_vc49ZcU
Phillip Slawinski
Fri Oct 03 2008, 01:18PM
Phillip Slawinski Registered Member #1732 Joined: Thu Oct 02 2008, 02:34PM
Here's my 6" coil. This coil was built over about three months, and it still isn't finished. I can't really go any further with it until I move out of this apartment. I can't test the coil easily for obvious reasons.
Secondary: 900T [25 inches] 22AWG on 6" form
Topload: 7x30" + 7X24"
Primary: 13T 1/4" Copper Tubing
Tank Cap: 2X 50kV .025uF Maxwell Pulse Caps
Transformer: 14.4 Pole pig [in the image below] Soon to be powered by a bombarder.
2856512922 Bde7e92ffd M
I've also built an 833C VTTC. I'm currently getting a maximum of 34" of spark out of the coil in stacatto mode.
2821197391 Ba2b9fff5a M
LithiumLord
Mon Oct 13 2008, 09:19AM
(offtopic)finally managed to solve that e-mail stuff :)
My flower-pot SSTC, running 240vac from a variac. 30A H-bridge with a tricky optocoupler-based drive, the system is feedback-based and has an internal noise-rejecting interruptor triggered by external strobe from a remote control as well as any other strobe source. The secondary is 40cm high, painted with black spraypaint.
Th IMG 0495
A short clip on YouTube
Robert2
Tue Oct 21 2008, 07:09PM
Robert2 Registered Member #1773 Joined: Tue Oct 21 2008, 06:56PM
My first TC:
F860665ddffcf8f4m
45077aab12ffbc1em
And my first SSTC :P
81 1223762981 Thumb
TC 0,01 magnet wire , power by flyback, he have 1200KHz,
SSTC: 0,18mm, 16cmx40cm gived 120KHz, power by halfbridge of IRFP460,
More info, photo in my movies.
SSTC:
MCT:
Florian
Fri Nov 28 2008, 07:19PM
Florian Registered Member #1827 Joined: Fri Nov 28 2008, 07:05PM
I am new to this forum, here are some of my coils.
0,5inch SG-Coil (Newest one)
Secondary: 1440 turns with 0,05mm enamelled copper wire on 75mm winding lenght
Transformer: OBIT 20mA 12KV
Max. Sparks to ground: 140mm (1,8 x winding lenght)
Tank cap: 2,2nF @ 12,5KVDC WIMA MMC
Th
Img18th
Florian
Fri Nov 28 2008, 07:37PM
1inch SG-Coil (Newest one)
Secondary: 1200 turns of 0,15mm enamelled copperwire on 165mm winding lenght
Transformer: double or triple OBIT ~40mA@12KV
Max. Sparks to ground: 330mm (2x WL)
Tank cap: 2,7nF@13KV WIMA MMC
Th
Teslacoil 1inch 57 Th
Florian
Fri Nov 28 2008, 07:41PM
2inch SG-Coil (Newest one)
Secondary: 700 turns of 0,315 enamelled copper wire on 240mm
Transformer: dual Neon 12KV@150mA
Max. Sparks to ground: 600mm (2,5x WL)
Tank cap: 6,8nF@12,5KVDC WIMA MMC
Th
Img01th
Florian
Fri Nov 28 2008, 07:46PM
3inch SG-Coil (Newest one and best of my coils)
Secondary: 966 turns of 0,4mm enamelled copper wire on 370mm
Transformer: dual Neon 12KV@150-300mA
Max. Sparks to ground: 1000mm (2,7x WL)
Tank cap: 14,6nF@18,75KVDC WIMA MMC
Sparkgap: 9 stage static gap
Th
Img17th
Florian
Fri Nov 28 2008, 07:51PM
4inch SG-Coil
Secondary:
1025 turns 0,6mm enamelled wire on 625mm
Max. Sparks to ground: 1250mm (2x WL) -> No finished yet
Tank cap: 30nF@18,75KV WIMA MMC
Sparkgap: Stativ vacuum-singlegap
Th
Img01th
