  • Guests: 68
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
** Add your Tesla coil here **
Linas
Mon Nov 26 2007, 05:30AM
SSTC 342KHz, half-bridge, with FDH44N50 mosfets, runs on 600-800W,
spark lenght is almost 30cm in big secundary, wich burns under my test....
now i using small secundary :(
1196055006 1143 FT14 3313123213123
teslacoolguy
Fri Dec 07 2007, 09:08PM
My first spark gap tesla coil. It is powered by a 7.5kv nst and a 50nf at 10kv mmc. the max spark is about 3.5" with 4" streamers to a grounded object
1197061690 1107 FT14 My Small Spark Gap Coil
1197061690 1107 FT14 Spark
KresoLiubov
Tue Dec 18 2007, 08:48PM
KresoLiubov Registered Member #1153 Joined: Mon Dec 03 2007, 07:27PM
SGTC
Made by me for display in Nikola Teslas birth house in Smiljan:
Secondary: 160 mm, 1000 turns of 0.1 mm double insulated HV wire
Primary: 6 mm copper wire
Capacitors: Maxwell X 4
HV transformer: Custom made 10 kV 100 mA
Spark gap: Series copper pipes
I replicated one more exactly same for History museum of Croatia. Spark length 1.5 m. Foirst one operate for more than one year where visitors turn it ON and OFF as much they want without any fails.
1198010923 1153 FT14 Dsc00002
1198010923 1153 FT14 Dsc00015
KresoLiubov
Tue Dec 18 2007, 08:53PM
One of many SSTC-s.
TL494 driven
1198011179 1153 FT14 Dsc01041
1198011179 1153 FT14 Dsc01017
KresoLiubov
Tue Dec 18 2007, 08:58PM
Feedback SSTC
1198011498 1153 FT14 Dsc01373
1198011498 1153 FT14 Dsc01361
KresoLiubov
Tue Dec 18 2007, 08:59PM
KresoLiubov wrote ...
One of many SSTC-s.
TL494 driven
Edit: I just counted more than 30 documented so i will not post photos of all dead
Wed Dec 19 2007, 07:06PM
My first working SSTC. Based on Steve Conner's PLL driver, runs from half-wave rectified mains, secondary fres 500kHz, secondary height = 20cm. Needs primary tuning, but I consider it complete for the time being. Link2 Link2
1197148926 95 FT34743 Complete And Mounted On Board Wetted Breakout Point
bluemotion
Sat Jan 05 2008, 12:25PM
bluemotion Registered Member #1200 Joined: Mon Dec 31 2007, 01:43PM
My first SSTC, it's basically Steve's Micro SSTC, but I replace the TC4420 with UCC37322 and add an interrupter. The interrupter is the same as the one used in Steve's Class-E.
It runs from a 30VDC, secondary frequency is unknown yet.(taken from my old SGTC) Topload is a stainless steel sphere(2inches in radius). With interrupter, streamers reach 4cm while IRFP460 staying cold.
]1199535336_1200_FT14_mov00139.avi[/file]
1199535336 1200 FT14 Dsc00138
1199535336 1200 FT14 Dsc00136
1199535597 1200 FT14 Dsc00132
Ultra7
Fri Jan 11 2008, 11:34PM
This is My SGTC.
4 Inch Primary wound for 18 inches.
7500V/30mA NST
.0107uF Cap using 14 .15uF/2000V CD Snubber caps
Primary is 3/8 in tubing with 1/2 in spacing.
Toroid is El Cheapo Hobby store styrafoam donut covered with Al Tape.
1200094403 1157 FT14 Tcgaragemed
1200094403 1157 FT14 Cdburner
bluemotion
Sat Jan 12 2008, 01:41PM
My first half bridge SSTC. It's almost the same as Steve W's MiniSSTC. However I use 2 ucc37322s since I only have them.
It runs on full wave 110v main.
I am still using the secondary wound for my last MicroSSTC, it's 19cm in height.(30 cm with breakout point; 41cm with stainless steel sphere)
secondary freq is around 615khz
When using a sphere as topload, sparks reach 14cm.
1200124475 1200 FT0 Dcp 3076
1200143874 1200 FT37300 Dsc00189
]1200145265_1200_FT14_mov00158.avi[/file]
