  • Guests: 46
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
** Add your Tesla coil here **
Tesladownunder
Tue Mar 28 2006, 05:18PM
RSmith July 13 2005
Tube coil running near several light bulbs
1143566305 10 FT14 Tesladis211
Tesladownunder
Tue Mar 28 2006, 05:19PM
Reaching July 26 2005
My newest SGTC Work. Midi 3
Transformer: 7,5kV 50mA NST
Primary: 8 Turns (connected at 7,7turns)
Secondary (7,5cm Diameter 37cm in height, wound with 0,3mm Wire)
Spark Gap: Multi Gap (6 Elektrodes) with 90mm Pc Fan
Toroid : 30x10cm
Maximum Sparklenght: around 70cm or nearly 28"
For more Info(pics etc), visit my Website
1143566386 10 FT14 Settupp1
Tesladownunder
Tue Mar 28 2006, 05:21PM
Connor Mc Steve July 19 2005
The Turbo Triodal Tesla-2
This is my old Tesla-2 spark gap coil, that I decided to max out with some help from Alan Sharp and Richie Burnett.
We added an extra 25nF @ 20kV of commercial pulse caps in parallel with the existing 12.5nF cap, and installed Alan's huge "triodal" topload made from multiple salad bowls from Woolworths and Ikea.
We then turned the power supply and gap motor up as far as they would go and watched the fun :-/ We shut it down when it started striking the tank capacitors as we were worried about damaging them.
The single MOT, multiplier stack and charging chokes seemed fine even though they were designed for 1kW and probably were supplying nearer 3kW. The gap electrodes melted, the gap motor bearings failed, the secondary was burnt by racing arcs, and we blew several 5 amp fuses.
All good fun
1143566508 10 FT14 Turbotriodalsmall1
Tesladownunder
Tue Mar 28 2006, 05:23PM
mattrg July 25 2005
More of the coil in view...Specs can be found in the thread under projects...
1143566622 10 FT14 Dscf02901
Tesladownunder
Tue Mar 28 2006, 05:25PM
mattrg July 25 2005
El gordo
1143566723 10 FT14 Dscf0290 Edited1
Tesladownunder
Tue Mar 28 2006, 05:26PM
sf8389 Aug 05 2005
Thes is a pic of my coil.
1143566818 10 FT14 Tesla Coil1
Tesladownunder
Tue Mar 28 2006, 05:28PM
sf8389 Aug 05 2005
This is it running about 20" arcs to a grounded object it maxes out about 25" streamers.
Power: 2 12kv 30ma modified with 5 shunts removed
?100ma?
Capacitor: .02uF rolled polyethylene
Toploads: both 3" minor diameter one major 10" and 15"
Secondary:4" diameter 643 turns ran out of wire so two different wire sizes 19 and 22 ga 30" tall
Primary:1/4 cu tube about 7 turns tuned
1143566902 10 FT14 Tesla Coil 21
Tesladownunder
Tue Mar 28 2006, 05:29PM
philer Aug 05 2005
My second working Tesla Coil (But its a bit out of tune)
Technical Data:
Secondary: h: 64 cm
d: 16 cm
wire: 0.42 mm
Primary: d1: 24 cm
angle: ~5°
w: cu 8mm
n: 12 turns
Toroid: d1: 64 cm
d2: 16cm
Cap: 50nF mmc (wima fkp-1)
PSU: 4-Mot-Stack (without oil) ballasted with mots.
power draw: unknown (no ampmeter)
Sparklenght: about 5 feet
1143566987 10 FT14 Img091
Tesladownunder
Tue Mar 28 2006, 05:31PM
Ronald Aug 09 2005
Okay whit many thanks to tc down under i am able to show some pic's
This is the first coil i've build
Its a litle big but HEY youve gotta start somewhere...
Sec: 250mm diam
1850mm 1600 turns long
1mm wire
80 khz
Running on 4 Motstack whit no limits at all when the wiring smoke's its time to stop
Stil trying to get the cde caps so if someone is able to get me 40 caps for a resonable prise please let me now.
1143567114 10 FT14 Sg Coil11
Tesladownunder
Tue Mar 28 2006, 05:36PM
Ronald Aug 09 2005
Then my next coil
This is the vttc type
I've build this coil to test the GU-21b tube and to test my skils in building a vttc.
This is a coil whit far to litle turns on the sec.
A to much power on the prim.
This picture shows the testing stand...
The Gu-21b can take as much as 10 Kw
It runs on a filament of 8.5 volts at 150amp. rms
1143567375 10 FT14 Teslavttcronald1
