  • Guests: 36
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
oneTesla - a small single-board DRSSTC
Mon Aug 06 2012, 04:39AM
I killed my bridge running ~350A at up to 120uS on-time and continuous polyphonic operation for about a minute with ~14" white hot ground strikes (this was with a smaller coil than the 23" spark one).
Have you observed the switching waveforms and primary current during this condition? Maybe you can gain some insight as to what the devices are really putting up with during this condition.
I guess this is why i never settled for anything without active current limiting.
Dr. ISOTOP
Thu Aug 09 2012, 12:42AM
@Killa-X: the interrupter uses an ATMEGA328P-PU
Thu Aug 09 2012, 07:53PM
E.TexasTesla Registered Member #4362 Joined: Sat Jan 21 2012, 03:44AM
Just ordered on of your boards off ebay.
One quick question for you
will the FGH60N60SMD interchange with the FGH60N60SFD igbit?
Both the data sheets look similar except for saturation voltage.
Thanks.
Ben Solon
Thu Aug 09 2012, 08:17PM
any reasonably rated igbt will "work", its efficiency that changes. and with a higher Vce sat. the igbt will drop more voltage for the same current, limiting the power you can push before burning past the 150deg C rating of semiconductors.
Dr. ISOTOP
Thu Aug 09 2012, 09:03PM
E.TexasTesla wrote ...
Thanks. Chris "Jencoautomotive"
The SMD is definitely the better IGBT, since it has lower Vce and, more importantly, is faster.
Thu Aug 09 2012, 09:36PM
Thanks for the information. Im looking forward to the buildup.:-)
Dr. ISOTOP
Sun Aug 12 2012, 05:48AM
Lots of delicious oneTeslas:
Ntesla
Killa-X
Sun Aug 12 2012, 04:34PM
Lot more turns than I use but hey, different cores - different winding!
Now you just need to wire them up and put 8 coils evenly spaced all around you playing music in accordance to surround sound...
Dr. ISOTOP
Fri Aug 17 2012, 08:16PM
Ntesla Tower
^putting all those nuts onto those threaded rods was an interesting experience
Ben Solon
Fri Aug 17 2012, 09:41PM
parallel them suprised
