  • Guests: 46
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
oneTesla - a small single-board DRSSTC
Mon Nov 05 2012, 04:17AM
E.TexasTesla Registered Member #4362 Joined: Sat Jan 21 2012, 03:44AM
Yes both probes were set x10.
Dr. ISOTOP
Thu Nov 15 2012, 08:56AM
You can do a simple test by removing the current transformer and driving the CT pins with a 250KHz sine wave, while the interrupter is installed. If the signal at each IGBT gate is a reasonably nice 0-15V square-wave, then you can assume the signal pathway is intact and you did something silly on the power end of things.
Dr. ISOTOP
Sat Nov 17 2012, 12:38AM
...and, it turns out the coil was out of tune the whole time
here it is with a 2x8" spun toroid, slightly lower (!) on-times than before
teravolt
Sat Nov 17 2012, 02:31AM
what do you think your primary current is?
Dr. ISOTOP
Sat Nov 17 2012, 10:18AM
teravolt wrote ...
Last I checked, it was around 300Apk
teravolt
Sat Nov 17 2012, 06:12PM
that is ia nice setup, is that little ciol working with your new board? have you thought of selling that coil in your last video as a kit.
Dr. ISOTOP
Sun Nov 18 2012, 04:22AM
teravolt wrote ...
Yep, the new board adds a few little features such as a MIDI-signal-present indicator lamp and a fuse. It also tightens up the layout of the controller.
teravolt wrote ...
This has been in the works for a while; expect to see kits for sale soon, complete with laser-cut acrylic components and (cheap) optional pre-wound secondary.
For now, as usual, if you want a board you can PM me.
New pics
1353212558 2919 FT139829 Board
1353212558 2919 FT139829 Box
1353212558 2919 FT139829 Stacks
Sun Nov 18 2012, 04:27AM
Dr. ISOTOP wrote ...
really cool box!
Sun Nov 18 2012, 07:46PM
Ok, with the CT out of the circuit and a 200 khz (my signal generator only goes up to 200khz)
signal substituted both my igbt gates are still not square. The signal going into the gate transformer is also not square.
I think im done with this circuit. It looks nice and I beleive you guys did a good job with it but Ive blown way to many parts and money.
As far as the board and traces go they are in poor shape. This pcb was not designed to handle any repairs.
Desoldering with the correct tool still pulls traces up.
Dr. ISOTOP
Sun Nov 18 2012, 08:01PM
E.TexasTesla wrote ...
I think im done with this circuit. It looks nice and I beleive you guys did a good job with it but Ive blown way to many parts and money. If someone wants this for parts I will put it on ebay or trade for something.
The IGBT's don't particularly enjoy being desoldered.
The IC's should be socketed; desoldering a 14-pin package is nearly impossible even with proper tools.
