  • Guests: 43
Inducktion (32)
Standa (31)
nabzim (33)
12/23 David (39)
12/25 Kolas (18)
SMPS Flyback question
zippotix
Mon Jun 18 2012, 05:32PM
zippotix Registered Member #5208 Joined: Thu Jun 07 2012, 06:12PM
Sorry for being such a pain in the a$$ :). I saw your video of ZVS, and what caused the fail of flyback? Secondary got burtn, yes?
Newton Brawn
Tue Jun 19 2012, 03:11AM
Zippo !
The capacitor MUST BE IN SERIES with output uf the halogen transformer !
If you put the cap in parallel with the hallo trafo >> PUF! the cap or the hallo is finished !
Regards
Newton
Dri0m
Tue Jun 19 2012, 05:31AM
Dri0m Registered Member #4497 Joined: Thu Apr 19 2012, 12:53PM
zippotix wrote ...
well, I had 50kV on output, and arc started directly on DST and burned it's surface, but it can still work if i clean it :)
zippotix
Tue Jun 19 2012, 01:50PM
Oh, well, but these arcs were insane :). Hey Dri0m, I can't get torroid ferrite, but I have broken flyback core. I was thinking that it could work similar as your inductor. I'm posting the pic, please tell me what you think Link2
Dri0m
Tue Jun 19 2012, 02:56PM
zippotix wrote ...
You can use any ferrite core, but idk how many turns, i think it should be >50 turns. i don't have any free DST ferrite, so i can't measure it.
zippotix
Tue Jun 19 2012, 06:43PM
Hm, ok. One last question (I hope, lol); can I power the ZVS with halogen transformer if it's AC?
zippotix
Wed Jun 20 2012, 03:59PM
Nevermind, I assembled the zvs as on the circuit, but I'm sure I did something wrong. All it gives is slight humming and when I touch the HV ground pin it sparks with barely visible very small "arc". Guess I'm not cut out for electronics ;), I give up.
brandon3055
Wed Jun 20 2012, 11:38PM
zippotix wrote ...
Don't give up just try again it onec took me 4 hours to find a faulty trimmer but that's no reason to give up
Btw sounds like its working maby there's not enough power how many primary turns are you using? Also I get 1mm arks when I fry the transformer but that seems unlikely in your case since you haven't had it running yet but try changing it anyway maby the tv you got it from had a bad flyback
zippotix
Thu Jun 21 2012, 07:55AM
Destroyer of mosfets, thanks, I'm gonna give it another shot. I dismantled the whole thing and will start from the begining. I tested flyback with SMPS, and it works like nothing happened. I'm certain I connected the mosfets correctly, but messed something up with 4007's and zeners. Maybe it's like that cause I plugged 11VAC in there, and it runs on DC only? Oh, and inductor (self wound 25 turns, toroid from PSU) gets very hot after a while of "running". Primary on flyback is 6+6turns. Oh, and flyback was bought new at the local RTV shop :).
zippotix
Sun Jul 01 2012, 05:34PM
Ok, I've got it to work last week. At 36V it really kicks a$$, but overheats a bit, I'll just get better heatsink. But I'm still curious about the original question. I tried adding a .68uF cap to the halogen transformer output and it didn't affected the HV output. Maybe a smaller capacity capacitor would do better? What do you guys think?
