  • Guests: 34
plazmatron (48)
rm203tech (17)
Duality (16)
Jiffycoil (65)
Dandrion (69)
12/21 Inducktion (32)
12/21 Standa (31)
12/21 nabzim (33)
Life Below 5 keV
first  3 4 5 6
Sat Jun 16 2012, 05:19PM
Charging Electrode and Double Box Details
1339866552 543 FT0 Charging Electrode Face View Upload
The solder spot is the through-hole termination of the bias input lead.
1339866575 543 FT0 Charging Electrode Side View Upload
I used the same standoff arrangements used for the collector plate.
1339866615 543 FT0 Double Box Construction Upload
I will divide the electronics box into decoupled compartments so electrons can't start making their own unofficial and unapproved
voyages around the circuit.
Sat Jun 16 2012, 06:44PM
I've been following this project with some interest,
had a thought,
at the ,5 keV range I think that the wavelength of x-ray photons will be of the same order as the atomic spacing of many solids (or am I way out?)
which means solids may act as bandpass filters etc?
Sat Jun 16 2012, 08:20PM
Sulaiman wrote ...
had a thought,
If we first consider the case of visible light, diffraction occurs in a diffraction grating when the spaces between the lines are of the same order as the wavelength of the arriving light - a few thousand Angstroms.
The interatomic spaces in crystalline solids are conveniently of the same order as x-ray wavelengths, so the rays can be diffracted by the repeating patterns of atoms, a fact from which the huge field of x-ray diffraction has evolved since its discovery by Laue in 1912 - a hundred years ago.
A crystalline solid can disperse x-rays according to wavelength (Bragg's Law), just as as a diffraction grating can disperse white light into the colours of the rainbow. This makes it possible to select a particular wavelength, a process used in monochromators to produce (ideally) x-rays of a single wavelength.
None of this is peculiar to the ultra-soft, and I am wondering if you are thinking either of the famous x-ray 'water window' - 280 to 530 eV - which is at the heart of x-ray microscopy of biological specimens, or of the strange and marvellous world of x-ray optics with its multi-layer mirrors and lenses formed from
exotic materials.
This project thread is very much about learning as I go along, so perhaps I'll be able to give you a much better answer later on. There's always hope! smile
Mon Jun 18 2012, 03:33PM
The 40GΩ resistor that calls itself 50GΩ
After having promised myself that I was going to have nothing to do with resistors of prodigious value, I found that the current noise in my T-bridge mod to the trans impedance amplifier was worse than a resistor of 50GΩ.
Reluctantly, I turned back to the resistors of prodigious value, which it turns out are also of prodigious cost if you want a human-friendly wire-ended one. Like £50 each!
This left me with only 0805 size chip resistors of which I found I had ten that had apparently cost me £1.72 each - still a ludicrous price for something the size of tea leaf. Looking at them in their packaging tape, I wasn't surprised I'd forgotten I had them. No one but a dalek could actually like them.
Anyway, I stuck two strips of copper tape onto a piece of PTFE about 1mm apart, and put spots of solder onto each of them. Using tweezers, I then set a chip resistor as a bridge between the two foil strips, and applied a 15W soldering iron.
1340031316 543 FT0 50g Resistor  0805 Resistor Upload
The resistor is 2mm from end to end
I was very dubious about this arrangement which has all the hallmarks of a real bodge, so I measured the resistance between the two foils with my Takeda Riken TR8601 High Ohm Meter, and found it to be 40GΩ - certainly less than I was hoping for, even at £1.72.
This made me go back to the product data, where I found that the tolerance of these chip resistors is only 30% - so my measured 40GΩ was within spec so far as the manufacturer was concerned:
1340031352 543 FT0 50g Resistor Data
And if I really wanted 50GΩ 1%, then there was always this season's range of exclusive Ohmite glass through-hole resistors starting at £49.58. Naturally, I decided that I had really wanted 40GΩ all along...
plazmatron
Mon Jun 18 2012, 04:54PM
Rather you than me!
How do you intend to protect that tiny resistor from surface leakage, or any kind of surface contamination?
I have always found high value resistors like this, quite a challenge to work with.
Proud Mary wrote ...
Ha! Frequently my projects are driven by outcomes like this, and sometimes by serendipity...
Les
Mon Jun 18 2012, 05:34PM
plazmatron wrote ...
Rather you than me!
Les
I discovered that the resistance was 35GΩ at 100V, 37GΩ at 50V and 40GΩ at 10V - these are the kind of figures you get with gigohm resistances when a guard is not used to mitigate surface leakage. The size of the thing made it impossible to wrap a wire round it and take it to the meter's guard output, so we should take it that 40G is the total resistance of the part in parallel with the (possibly variable) leakage paths on the outside.
As for surface contamination, the resistor will be operating inside a sealed, dessicated box, but I don't find this very reassuring.
I may coat the resistor and its surrounds with clear acrylic nail polish, and then measure its resistance again when the varnish has hardened, to see if it is still usable.
I have worked out that a 10GΩ resistor will just do if I upgrade the amplifier. I've sent off for a rather large 10GΩ 3W 5% resistor for £3.11 inc p&p, so that I have a standby if the 40GΩ starts to drift, or doesn't recover from its nail polish make-over.
radhoo
Sat Jun 23 2012, 09:11PM
great design on the ion chamber, and a very interesting project that I hoped for a long time to see happening.
once you get over the high ohmic resistor issues, and get the tiny ion chamber current (well, maybe not so tiny at the x-ray intensity you are going to generate) translated into a measurable voltage, how do you plan to amplify that while keeping noise down?
already having a suitable Op amp in mind?
Sat Jun 23 2012, 09:31PM
radhoo wrote ...
I'm working on it right now, Radhu! smile I've tried several designs so far. At the moment, I'm trying an FET source follower with a constant current BJT in the source lead, to get a gain hopefully >0.99 and ultra-high impedance. Then I will have a two stage amplifier - either OPA177 or OPA200 - because I have some of both. Once I have something that is stable, I will add refinements, one at a time, to see how I can improve it.
Sun Jun 24 2012, 03:00PM
Glass stand-off insulators
This is how I make glass stand-off insulators using 4mm glass beads and 6mm self-adhesive copper tape. The glass beads cost 99p (EUR 1.24) per 100.
A 5mm punch cuts copper foil disks just the right size to stick on top of the 4mm glass beads. A block of hard wood placed under the copper foil,
and good sharp tap of the hammer, helps to ensure a clean cut. The cut discs go up inside the barrel of the punch, and have to be pushed out in a
column like a core bore through sedimenatry rock. A few of them get damaged in the prcoess.
1340548548 543 FT0 Glass Standoffs Tools Upload
It can be a bit fiddly peeling off the self-adhesive backing, but a scalpel blade will easily lift an edge.
1340548591 543 FT0 Glass Standoffs Upload
The completed stand-offs are ready to be stuck to the PCB copper ground plane with 5-minute epoxy.
IntraWinding
Mon Jun 25 2012, 05:42PM
Could you direct backscattering electrons away from your Beryllium window by applying to it a suitably large negative bias voltage, reducing the heating effect and thus enabling a thinner window to be used?
first  3 4 5 6
