  • Guests: 66
pspice
first  2 3 4 5
Fri Jun 08 2012, 08:41PM
Ooh, an enterprise-strength flame war! smile
I'm actually quite hopeful that Subversion would do something sensible if you asked it to merge two Eagle schematics in XML format.
Whether the back-annotation would survive is another question altogether :O
Nicko
Fri Jun 08 2012, 09:48PM
Steve Conner wrote ...
Nah Steve. Not worth it smile
Mon Jun 11 2012, 06:22AM
DXF is a dreadful format. There are about 10 versions, and the files don't even know whether they're in millimetres or inches. However, it is human readable.
XML, I always wonder what it is good for. Our customer insisted that the instruments we make for them should save results in "XML format". Of course that is no help whatsoever, XML is a language not a file format. So I did the enterprise thing and asked them for a DTD. They didn't have one, but they did have some example files from the previous instrument, would that do? And so on. I ended up working with another contractor who was writing the Windows-based analysis software, sending test files back and forth. We didn't bother to write a DTD once we were done either. smile
The switch to XML always annoyed me, as I had to write an XML parser and I lost the ability to load the results files (which were originally CSV) directly into Excel.
The other day, I had a lot of files to process, and I discovered that I could write an XSLT import filter for OpenOffice. But this same trick won't work for Excel: Microsoft's XML file format is incompatible with Oo's.
Agilent VEE uses a file format similar to XML, but with Lisp s-expressions instead of angle brackets. The Lisp people claim that they invented XML 50 years ago, just with round brackets instead of pointy ones.
I think my point is that there is no magic bullet. The shape of the brackets hardly matters, the real problem is interpreting the content.
first  2 3 4 5
