  • Guests: 42
Balls
Patric
Sat May 12 2012, 08:25AM Print
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
:-D
1336811063 2899 FT0 Balls
Héhéhé!
Sat May 12 2012, 06:31PM
Gazing globes is an older rich people thing to throw in garden pools and dams, now cheap and widely accessible for normal people with kids pools and high voltage enthusiast looking for a cheap sphere top load.
Alex M
Sat May 12 2012, 09:46PM
I say tongue
Killa-X
Sun May 13 2012, 12:15AM
Nice thing is they come in many many colors, yet are still metalic. Yellow, gold, silver, blue, purple, green, teal, etc ;)
Jrz126
Sun May 13 2012, 01:08AM
Jrz126 Registered Member #242 Joined: Thu Feb 23 2006, 11:37PM
Are they metal? I thought about using one of these when I first started with TCs. I bought one from walmart, turns out it was glass, with the metal coating on the inside.
Sigurthr
Sun May 13 2012, 02:42AM
I've only seen the glass ones locally. I ended up buying a 4" spheroid from Information Unlimited.
Patric
Sun May 13 2012, 08:25AM
Jrz126 wrote ...
They are metal, and even can be soldered! (I solder a needle on top of it)
Tetris
Sun May 13 2012, 06:46PM
I'd use one for a VDG generator not a tc lol (even a toroidal topload won't stay on my coil, nearly knocked it off onto me.
Sigurthr
Sun May 13 2012, 10:07PM
If they are indeed steel then you can drill a hole in the base and use a bolt as a support. I agree though, a perfect sphere may not be the easiest to mount, unless you use an outward facing pvc endcap on top for it to rest in.
Patric
Mon May 14 2012, 05:52AM
I glue the ball on the plastic tube with TEC7. Never fails!
