  • Guests: 31
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
10/17 Madgyver (40)
CSU Chico Tilt Rotor Flying Machine, (Airframe and Electronics, 2 of 3).
Carbon_Rod
Sat Jun 30 2012, 01:43AM
You will need to calculate lift over flight-time at operational altitude.
Sat Jun 30 2012, 02:44AM
Yes, that will be the next step, controllibility first, then capability...
AndrewM
Sun Jul 01 2012, 03:43AM
Video please? What was the final configuration?
Sun Jul 01 2012, 06:01AM
AndrewM wrote ...
yep let me post a pic for now, im trying to figure out how to use a GoPro ATM.
1341122499 2431 FT136218 Sam 0005
1341122499 2431 FT136218 Sam 0009
I crashed it after i "whiskey throttled" the collective. But im rebuilding now, fortunately tilt rotor with fixed pitch dont have all the expensive little parts that helis have.
Im hoping this among other sources will help me avoid saturation of the several integrals ill be maintaning... Link2
Sun Jul 01 2012, 08:50AM
Good stuff! I see you're not using the wooden pole to damp oscillations any more. How did you get rid of that? From the pics it looks like you're dangling the battery pack underneath now.
Sun Jul 01 2012, 11:40AM
Steve Conner wrote ...
First, as for the pole. Yes we've done away with it, now that ive pushed some mass out left and right, those rotational moments are slower and the gyro+math can keep up from the kk board.
second, hanging the battery was a huge help, and remember i said i was wondering if the CL should be well above the CG, well it pretty much has to be (a pendulum) or pitch changes are erratic or have no effect.
i like this more than my quad, as theres half the props, half the motors, and half the ESCs, so its cheap to fix. And a camera/sensors are easier to mount with better field of view than from a quad.
AndrewM
Tue Jul 03 2012, 03:13PM
VIDEO!!!
You've just built a tiltrotor, you really expect me to believe you can't figure out how to upload some vids?
Tue Jul 03 2012, 05:32PM
AndrewM wrote ...
VIDEO!!!
i can build UAVs, and plan to build spacecraft, but they still wont give me a degree in EE!
Tue Jul 03 2012, 09:49PM
You don't need a degree in EE to operate a GoPro! Vids or it didn't happen smile
PS: You might need one before anyone will let you near a spacecraft.
AndrewM
Tue Jul 03 2012, 10:18PM
Ha, if that was the requirement nothing would ever get built around here! Based on the number of connector jackposts that get twisted off, inspection mirrors shorting out battery cells, and ESD bags left over TC&R antennas I'd wager a HS diploma isn't even a requirement...
I propose a boycott of all of Patrick's threads until he posts video.
