  • Guests: 41
SSTC-2
Mon Mar 26 2012, 08:29PM
For 240V mains, you get 320 to 360V when rectified. The IRFP460 works well off this.
The HGTG30N60xxx IGBTs are 600V rated so they would be fine too.
Tue Mar 27 2012, 06:32AM
so would it be better to go with HGTG30N60?, and if so where should i get them, ebay?
Note: will be first TC
thanks,
Tom Williamson
Acacia
Tue Mar 27 2012, 08:58AM
Acacia Registered Member #4073 Joined: Sun Aug 28 2011, 08:43AM
Where abouts are you? If your in Australia, I would suggest Element 14, postage is free and arrives in a day or two.
Nic
Tue Mar 27 2012, 03:53PM
I be in Dorset
Wed Mar 28 2012, 04:55AM
ben123324 wrote ...
wait. you have no need for doubling, and your mains voltage is what us in the USA would get using a doubler. so just inverse the operation. use a full wave bridge rectifier to charge two series capacitors. then the voltage across each cap is half of the total voltage. if you use a half bridge, you can use the tap between the caps for the "0" voltage. then use the top and bottom rails as your + and - rails. or plan accordingly if using a full bridge.
Interesting. I think this might be applied to the EVR microBrute I'm actually building. I'm gonna ask Dan.
