  • Guests: 46
My First Mini 811a Tesla Coil
TwirlyWhirly555
Mon Mar 05 2012, 05:37PM
TwirlyWhirly555 Registered Member #4104 Joined: Fri Sept 23 2011, 06:54PM
Hi
Thanks you two :) , One thing i have noticed is , even after tube has warmed up for 5 minuits ( long time i know ) , the arcs always start of small and over 30 seconds or so grow to normal size .
Its like as the tank capacitors warm up ; so the arcs get bigger .
Good luck on your 811a build :D
Luceš
Mon Mar 05 2012, 10:37PM
Luceš Registered Member #4108 Joined: Sun Sept 25 2011, 11:43PM
My gu-81m vttc did the same thing. I found it was because it was the wrong type capacitor. The spark length didn't really suffer, but the capacitor heated badly and it soon died
TwirlyWhirly555
Mon Mar 05 2012, 10:50PM
Luceš wrote ...
Hmm guess that isn't good then ; I purchased the capacitors from
On here and I've herd they are fine for VTTC coils , 780pf each at 30kv but they are fairly physically big considering size . They seem to get warm but don't change temp after the " warm up " at the start .
I did Plan on making a larger VTTC using these
Capacitors too .... I'll see what happens to the capacitors I guess .
Luceš
Mon Mar 05 2012, 11:08PM
Yours should be fine... Mine unsoldered itself :P
Mon Jun 18 2012, 09:37AM
Hi again TwirlyWhirly555 smile
I just finished my coil, it works great but I encounter same heating problems as you (secondary and tube) Link2
I just saw you solved your heating problems, but you reduced your coil performance from 4-5" streamers down to 3"...
You may want to have a look at Arcstarter's coil Link2 posted here Link2 , it is very close to ours ( in fact I tried to reproduce it wink ) and runs cool at full power...I am trying to understand what makes the difference....
cbfull
Mon Jun 18 2012, 03:37PM
cbfull Registered Member #187 Joined: Thu Feb 16 2006, 02:54PM
TwirlyWhirly555 wrote ...
Hi
That happened to me too, and you are correct. As the capacitors heat up, their value changes, bringing your coil into tune.
I made my own tank capacitor using Al foil, 1/8" glass plate and varnish. However, a digital capacitance meter is a must if you go this route.
