  • Guests: 40
  • Most ever online: 441
GhostlyFigures (36)
10/05 GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
Sstc
genious 7
Wed Feb 08 2012, 02:23PM Print
genious 7 Registered Member #2887 Joined: Sat May 29 2010, 11:10PM
http://www.instructables.com/id/Solid-State-Tesla-Coil
If you like it, please vote for me in the contest and rate it. If not, please tell me where is room for improvement.
ajacks504
Wed Feb 08 2012, 05:19PM
ajacks504 Registered Member #4396 Joined: Mon Feb 06 2012, 11:58PM
Can you attach a readable version of the main schematic here please?
Nice work BTW.
genious 7
Wed Feb 08 2012, 08:35PM
Just click them small i at the corner of the image that appears when the mouse hovers the schematic. I'd still recommend Steve Ward's sstc 5 driver, unless you cannot obtain some of the parts locally. (I couldn't)
ajacks504
Wed Feb 08 2012, 08:49PM
I see, thanks.
Thu Feb 09 2012, 01:00AM
E.TexasTesla Registered Member #4362 Joined: Sat Jan 21 2012, 03:44AM
Does you schematic work? I thought you had to have a GDT because Q1 and Q2 dont have a common source?
Looks nice.
Edit:
Sorry, I just looked up ir2110 and it has a floating channel just for that type of usage.
I think I will order a few of those drivers ;)
genious 7
Thu Feb 09 2012, 03:03PM
Regardless of it working, I suggest you to use a gate drive transformer if you can, as it provides galvanic isolation. Whats the advantage?
-Since MOSFETS fail closed, if it blows, the IR2110 and possibly something else will also blow.
-The 12v and 5v supply have to come from a transformer; no ATX supplies referenced to ground.
So... why did I did it?
-I couldn't find the UCC chips Steve Ward used
-I couldn't find a ferrite toroid and I suck dismantling those ATX transformers without breaking them.
