  • Guests: 128
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
a question about spark-gaps...
Sun Jan 15 2012, 07:43AM Print
i have built myself a spark gap, as the crappy temp ones made out of what ever was available were getting to be too dangerous.
so i built this:
1326613424 2431 FT0 Sam 0975
my question is this, how can a approximate the breakdown voltage...
do i use Paschen's law? Or just the 3MV per meter rule? my spheres are 0.625 inches dia. But when i look up the data tables i see them using 2 inch dia. spheres, does this matter?
EDIT: Jim Lux's HV handbook appears to not have his "sphere" table link working...
from HV wiki i see 30kV/cm. for spheres, DC... but it mentions nothing on radius.
Antonio
Sun Jan 15 2012, 01:16PM
30 kV/cm is when the spacing is much smaller than the radius.
This formula works:
Vbreakdown = E*4*d/(d/R+1+sqrt(sqr(d/R+1)+8))
E=30000 V/cm
d=gap spacing in cm
R=ball radius in cm
Mon Jan 16 2012, 01:32AM
Antonio wrote ...
This formula works:
E=30000 V/cm
d=gap spacing in cm
R=ball radius in cm
Excellent, once again antonio you save me!
I was wondering if the HVwiki article meant flat plate distance ?
UPDATE: This should be easier on the eyes...
1326679203 2431 FT1630 Untitledmath
I hate ASCII math anyways... (Wrong dont use this!)
EIDT: i think i did it wrong im getting numbers which are way to big... i see it now, goofed it.
i think this is right now...
1326680277 2431 FT1630 Untitledmath2
For a radius of 0.79 cm, a gap of 6cm, im getting 41 kV...
Mattski
Mon Jan 16 2012, 03:52AM
Looks like a useful reference.
Antonio
Mon Jan 16 2012, 12:17PM
Paschen's law applies to very small gaps, where the breakdown voltage appears to rise when the gap is reduced. The essential effect is that if you find a breakdown voltage smaller than about 300 V the calculation is not valid. No sparks occur below ~300 V, no matter the distance.
For a radius of 0.79 cm, a gap of 6cm, im getting 41 kV... Correct. 40808.7 V by the formula.
It's useful to add a scale to one side of the gap.
Newton Brawn
Wed Jan 18 2012, 02:26AM
Hi Patric, Hi Antonio !
Here the sparg gap that Im using in the Arc Starter. There are 3 tungsten carbite bits, aligned and keeping two air gaps of 0.3mm.
Im very interested to evaluate the voltage breakdow in such arrangement.
Any calculation ?
Thanks
Newton
Sorry, Im trying to attache a dwg and a pic
Wed Jan 18 2012, 02:28AM
do you have a pic? also are your carbides having 90 degree corners?
Newton Brawn
Wed Jan 18 2012, 02:35AM
Any calculation ?
Thanks
Newton
PS- the tung carbite bit angle is 55 degrees. pls see dwg
]a_alta_frequencia_-_maq.pdf[/file]
1326853940 3343 FT132318 Dscf0080
1326854048 3343 FT132318 Dscf0080
Wed Jan 18 2012, 03:14AM
Newton, ive seen your design in previous thread seraches... my research for my own gap.
Are those tile cutting pieces?
Andyman
Wed Jan 18 2012, 06:14AM
They look like standard indexable cutting bits for a lathe/mill
