  • Guests: 58
Primary Capacitor
Wed Jan 18 2012, 02:30PM
FKP1 are very similar construction to CDE 942. They probably perform about the same, but the CDE 942 is probably cheaper in the USA because they're made there.
zzz_julian_zzz
Wed Jan 18 2012, 02:58PM
If I were to choose between 2 possible tank cap, Which one should I choose>?
A MMC using a MKT targeting to make 3200v @ 0.168uf from plenty of 330nf/600v
OR
a home made capacitor, Probably foil type rated 15kv/150nf
Which of these two will work for the best??
Wed Jan 18 2012, 03:09PM
Home made caps tend to die pretty quick from internal corona.
Wed Jan 18 2012, 10:02PM
MKT is polyester if I remember correctly, which has a loss factor several times higher than polypropylene. I would say get some MKP caps.
zzz_julian_zzz
Fri Jan 20 2012, 12:56AM
what do you mean by loss factor? does it mean that The performance form a MKT cap is much much lesser than with MKP?
thanks for the input
m4ge123
Fri Jan 20 2012, 03:38AM
m4ge123 Registered Member #4118 Joined: Mon Oct 03 2011, 04:50PM
Loss factor=power dissipated/reactive power (kVA)
Fri Jan 20 2012, 08:03AM
He has a point, MKT and MKS are indeed polyester (aka Mylar) Look for MKP or FKP instead.
T stands for terephthalate or whatever the chemical name for Mylar is.
zzz_julian_zzz
Sun Feb 05 2012, 03:28AM
it could have loss factor, but still the arc output is still the same?
