  • Guests: 61
Flyback Transformer Plans/schematic
first  6 7 8 9
GFH
Mon Jan 16 2012, 04:22AM
GFH Registered Member #4324 Joined: Mon Jan 09 2012, 03:16AM
Yes. The HV grounds on what I perceive to be Pin 8 (could be Pin 3 if I start at the other end) but using the previous drawing as a guide it would be Pin8..
Mon Jan 16 2012, 04:30AM
GFH wrote ...
doy you have a DMM? you may have to ohm out some of those pins like 1 and 5...
GFH
Mon Jan 16 2012, 04:34AM
I do have a DMM sitting right in font of me was planning on doing some probing..
Mon Jan 16 2012, 04:40AM
if we only new which coils whould be best for your voltage. im thinking first you confirm the pins count from the lowest left on my pic, clockwise the the right... then, youl have to connect your driver at low current, and see what the output is...
GFH
Mon Jan 16 2012, 04:42AM
yes that would be nice info..
Mon Jan 16 2012, 04:45AM
just dont let your lead acids make any copper wires glow bright red, that would be bad....
GFH
Mon Jan 16 2012, 04:56AM
But it will keep me warm:)
Suppose 4 and 7 could be it too..
Mon Jan 16 2012, 05:15AM
yeah in was thinking 4 an 7 too, maybe a small ancillary coil would be of a lower voltage, and so more useful for your purposes.
GFH
Mon Jan 16 2012, 11:22PM
Think I'm officially obsessed!
Ok I give up. I tired windings down to 2 then back up to 20. No more room for more winds, arc got smaller as winds reduced. Best up at 20 about 1.5 CM arc
Switched the Pots out to 50k and removed the 1k resistor. No effect, possibly slightly smaller arc.
Tried 24volts. no difference.
I give up on this circuit (for now, I'll come back 'cause it pisses me off:) )
I am going to try the ZVS Mazilla circuit and see what happens. After that I will rebuild the 555 version. Even if this one works I'll rebuild it from scratch again because something is obviously off.
Thanks guys
arrrgh.
Mon Jan 16 2012, 11:56PM
yeah, i think you need 30 or more turns then...
first  6 7 8 9
