  • Guests: 40
Flyback Transformer Plans/schematic
GFH
Sun Jan 15 2012, 06:44PM
GFH Registered Member #4324 Joined: Mon Jan 09 2012, 03:16AM
Alex (or Patrick)
Do you have guys have a thought on whether the number of windings or the gauge of the wire used on the primary makes a difference on the arc?
Going to try heavier gauge (14) (using 20 gauge and 20 windings right now) and less windings and see what happens just wanted you thoughts.
m4ge123
Sun Jan 15 2012, 07:32PM
m4ge123 Registered Member #4118 Joined: Mon Oct 03 2011, 04:50PM
Your mosfet has way more resistance than your winding so the wire gauge won't make a difference. Less turns should give you more voltage out.
GFH
Sun Jan 15 2012, 09:06PM
Thanks m4ge123
I shall experiment
GFH
Sun Jan 15 2012, 11:55PM
FYI
Tried reducing the windings from 20 to 15 to 10 and as they got reduced so did my arc/volts out.
Mon Jan 16 2012, 12:24AM
GFH wrote ...
FYI
The HV out will be a concave down parabola... the wire guage wont matter, but the number of turns certainly will.
As for the parabola, as X increases from 0 turns towards many turns, the Y-axis will equal output voltage, first the output will rise with an increase in primary turns, then with many turns youll reach a plateau, (the top of the concave down parabola.) Then with too many turns youll start seeing the output V start to drop down. There is an optimal number of turns but it varies wildly with each type and maker of flybacks and ampere-turns on the core.
Radhoo and Proud Mary really schooled my ass on using the internal primary, so far the best output ive ever gotten has been attained while using the internal coils.
try 30 turns then 40 and record the arc length... also, i hope you have your two SLA's in sereis, not parallel.
Alex M
Mon Jan 16 2012, 12:36AM
Patrick wrote ...
GFH wrote ...
FYI
Is it the same when using a low input voltage? like 12v? every time I tried using internal primary's arcs were always small.
GFH
Mon Jan 16 2012, 12:43AM
Well that's interesting Patrick. Think ill start with 4 and work my way just to see what happens.
I had the batteries in parallel (12v) just to keep the current up. I'll give it a go with 24 and see what happens.
I'm afraid I haven't had much luck finding the internal primaries yet. But I also admit I haven't looked very hard to find them.
I'll try that after I try the windings and voltage. Only want to change one thing at a time.
Thanks guys most educational
m4ge123
Mon Jan 16 2012, 12:46AM
Try increasing your input voltage and number of turns proportionally (if you double your input voltage, double the number of turns).
Mon Jan 16 2012, 01:08AM
Alex1M6 wrote ...
Once you make the decision to use the internal primary, you MUST use the voltage the datasheet specifies, thats the hard part, especially is you dont have the data sheet.
lets look at an example:
1311359943 2431 FT120576 Hr6329
follow my logic here:
first, i could use the pins 4 and 8, with 20V for a primary.
second, i can and currently am using pins 6 and 8, notice the phasing sign... that means 85-20 = 65 volts for this one.
third, i could also use the pins 11 and 10 and run them off of 165V.
Now it should be said that we might not have the wire awg visible, so on the low voltage coils we might have to artificially limit the current, since the reactive impedance might be insuffcient.
On that last one, 165V is really close to 120Vac FW rectified to 170Vdc, Te hee shades , im going to run it in off wall-socket power soon too.
EDIT: yes i would make one change at a time, otherwise youll blow stuff up and not know why.
GFH
Mon Jan 16 2012, 03:07AM
Thanks Patrick.
Explains why I didn't get anything when I tried what I thought were primaries at 12V :)
These are photos of what i have for a FBT. I've trying to locate a datasheet on it but can't
It's out of a 10 year old 19 colour TV, North America. Model is a Durabrand, obviously re-branded TV of some sort.
 Pins
Label
