  • Guests: 54
Barry (71)
Snowcat (38)
wylie (44)
02/01 Barry (71)
02/01 Snowcat (38)
02/01 wylie (44)
Peak primary current calculation
rulmismo
Fri Jan 13 2012, 11:14AM
rulmismo Registered Member #4187 Joined: Fri Nov 04 2011, 08:08PM
As Spice sims were confusing me, I did the derivation of the V0/sqrt(L/c) formula just to check it (adjoint).
I just discovered that to simulate the circuit, is not enough to give the Vc(0)=V0 as initial condition,
it must be given also IL(0)=0 or the result that the simulator gives is not correct (current goes to a false VERY large value).
]2012-01-13.pdf[/file]
