  • Guests: 65
DRSSTC stops working...
Thomas A.
Wed Jan 04 2012, 07:01PM Print
Thomas A. Registered Member #3905 Joined: Mon May 23 2011, 09:26AM
Hi,
I've built a medium size DRSSTC, it uses Ward's universal driver and it was working fine, until we tested the same circuit (driver and bridge) on our larger coil. The larger coil run burnt one of the IGBTs, and after we replaced the IGBTs (we tried several IGBTs from the same type) the original coil doesn't seem to work. If we test the driver, we can hear the GDTs voice as normal, but when we apply voltage to the half-bridge it produces one spark, and then nothing. After the spark the GDTs voice disappers almost entirely. If we discharge the capacitors and restart the driver circuit it does the same.
The over-current circuit is turned off so that can't be the problem and the current feedback is in right phase. The primary and the secondary is in tune (it wouldn't produce that spark at the begining).
Does anyone have any idea what can cause a problem like this?
Wed Jan 04 2012, 09:35PM
I have often experienced with SSTC and DRSSTC that when a MOSFET or IGBT blows, the gate resistor goes down with it. Try to measure if they are still alright.
Any resistors, zeners or diodes on the output side of the GDT would be a good idea to check.
zzz_julian_zzz
Thu Jan 05 2012, 01:17AM
I think it is on the feed backing circuit, It clamps/stops the oscillation due to phase lead configuration, try swapping the connection of GDT, CT, and PRIMARY one by one. Observe every combination per phase lead connection. But please, do Mad's suggestion first.
Thomas A.
Thu Jan 05 2012, 06:26PM
Thanks, for the advice...
I will try both tonight and post the result...
Thomas A.
Thu Jan 05 2012, 09:45PM
Finally, I figured out the problem. It was in the driver's feedback circuit. Two zener diodes were blown and some how the feedback signal turned into a constant high signal, after the first few feedback signals.
Thanks again for the advice!
zzz_julian_zzz
Fri Jan 06 2012, 12:39AM
Good for you, but did you figured out how / why it was blown?
The Lightning Stalker
Fri Jan 06 2012, 03:15AM
The Lightning Stalker Registered Member #4230 Joined: Sat Nov 26 2011, 05:50AM
I'm guessing the IGBT failed short circuit and the current went high enough to blow them up.
Dr. ISOTOP
Fri Jan 06 2012, 03:43AM
When IGBTs fail, if they fail with the gate short, it can leave a trail of dead silicon behind it (gate drive IC's, TTL logic, regulators, etc) as each chip may fail with input going low-impedance, drawing enough current from the output of the chip driving it to blow that one.
zzz_julian_zzz
Fri Jan 06 2012, 04:57AM
no igbt blown, we are refering to diodes.
teravolt
Fri Jan 06 2012, 05:43AM
hi zzz_julian_zzz hopefully the diodes didn't crash causing the igbt's to fail since that is responsible for synchronization
