  • Guests: 39
Sanchez (36)
Knarvel (13)
10/17 Madgyver (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
SSTC Pro's and Con's of half wave versus full wave rectified.
Thu Jan 12 2012, 11:08AM
Even if you just switched from full wave filtered supply to a half wave supply and kept everything else the same, the input power would went down around 4 times, but the sparks would be at least the same or even (in my opinion) a bit longer.
ScotchTapeLord
Thu Jan 12 2012, 01:24PM
Oh, I didn't read carefully. I understand now. I would argue that the coil could be kept identical if you raised the supply voltage rather than lower the primary impedance to satisfy that equal power at half-wave rectified requirement. Though, coilers aren't known to leave too much headroom for that, so I guess I should suggest lowering the supply voltage for the cw case.
