  • Guests: 78
IAmSpock (18)
01/29 IAmSpock (18)
01/30 Ian (37)
01/30 Lucas (40)
QCW coil
first  2 3 4 5
Gregory
Wed Jan 04 2012, 08:22PM
I however also sum my own integrated ramp back onto the feedback
First order delta modulator :>
But, for your integrator/acumulator amplifier you need a simetrical -5v to 5v supply, no?
I'm using TL3116 as comparator and TL072 as amplifiers/integrators.
I have already tryed to sum a small derivation term at the feedback, it help to get a better ripple/transient response. It acts iqual to the feed-forword capacitor, bacause this capacitor can be see as a derivator.
Now I need to make a good inductor hehe. I need to buy a inductimetter, mesure the indutance using ressonance sucks.
Goodchild
Wed Jan 04 2012, 09:50PM
Gregory wrote ...
You don't need a separate opamp or a split +5 -5 supply. I use a single TL3116 and a single +5V supply.
I actually use an RC network to generate the ramp that is summed back on the feedback ramp. The trick is to have the feedback ramp be larger in amplitude that the ripple of the output so that the comparator only looks at the RC ramp and not the ripple from the output.
Gregory
Thu Jan 05 2012, 12:10AM
If you are using only a single comparator I think that he is the quantizer (feedback - reference + histeresy). How are you adding the integrated ramp with not other amp? oO You need to make the integration.
Dr. ISOTOP
Thu Jan 05 2012, 01:17AM
Goodchild wrote ...
teravolt wrote ...
I don't know if any body is interested but I found this IC that I stumbled on and thought that this may be pertinent
teravolt that is an awesome little chip, it dose bang bang control a little bit differently than normal seems like it samples rather than running all the time. From my initial glance at the datasheet it looks like all timing is done internally rather than using external integration, as I said earlier this is a wonderful way to improve noise and load immunity on the switching times.
I may have to give one of these a try some time in the future.
Sadly that chip seems a tad slow; it can't do over 10 KHz, which is borderline for a QCW modulator and still audible frown
Gregory wrote ...
I believe he is using a passive RC integrator.
Gregory
Thu Jan 05 2012, 02:45AM
ohhhhh. Now I understand.. He is using the RC to integrate/acumulate. I was think that he was using the RC to generate the reference ramp with some PWM from a uC. Now all make sense.
Goodchild
Thu Jan 05 2012, 05:28AM
Gregory wrote ...
you got it.
teravolt
Thu Jan 05 2012, 06:58AM
hi Dr. Isotop, when I looked at the specs I think you are right that 10Khz sample rate is a bit slow. How ever for the bang bang control you probably don't need much more resolution for a ramp wave form of 5 to 20mS to filter. using a mbed for delta modulation is over kill you could probly use a adruino. cirtanly a microcontroler combined with hardware would be a awsum way to controle feedback and reduce parts count. I will probly end up using all hardware at this point for feedback.
Dr. ISOTOP
Thu Jan 05 2012, 07:17AM
teravolt wrote ...
Hmm I suppose a 10 mS ramp corresponds to just 100 Hz, so there's 10 KHz is a reasonable switching rate.
The micro doesn't really save parts, given that the comparator-with-hysteresis approach is a comparator and a few resistors. The Mbed is definitely *not* the way to go even with that approach; I used it because I happened to have one around at the time. If I do keep the software approach (which at this point looks less and less likely) I'd use this
Gregory
Fri Jan 06 2012, 02:03AM
Eric
I tryed to make some simulation in LTspice with a RC integrator and I get only sheet, hehehe.
I tried a simples quantizer/comparator (amp with ramp at +input and feedback at -input) , the output of the comparator driven the switch and at the same output the RC that summing at the feedback (-input).
teravolt
Fri Jan 06 2012, 04:35AM
hi Dr. Isotop that's a nice package lots of stuff on it. it seems that arm is prity popular to. I like MBED and Arduino because there is a large base of users. when it comes to software I'm prity much a newbie but when it comes to hardware I think of myself as not to bad. micros have a lot of potential.
Gregory, I kind of have the idea but do you have a schematic
first  2 3 4 5
