  • Guests: 47
RoV IW3IPD (63)
01/13 si2030 (62)
now thats what i call a arc!
Kizmo
Mon Nov 21 2011, 10:18AM
Whee 3ph ladders and arcage <3
Here is my old 3 phase 6pack
1321870706 599 FT128813 3phladder
Kiwihvguy
Wed Nov 23 2011, 08:19AM
Kiwihvguy Registered Member #3395 Joined: Thu Nov 04 2010, 08:42AM
Ash Small wrote ...
The 240V mains in your house is one phase of the three phase supply.
The three phase is 410V.
These voltages are the 'average voltage', called RMS voltage (root mean square).
If you google it, you will find a much better explanation than I can give here.
Don't you only get 415v if you use phase A and B or phase-to-phase? Phase to neutral is 230v in NZ (single phase).
I definitely think that David Rieben and that Danyk guy are the ones who have made the biggest arcs ever.
GrantX
Thu Nov 24 2011, 06:07AM
Although it is definitely not home-made, I think this is the most ridiculously powerful "Arc Machine" I've seen:
I translated the description, and it says something about a transformer cascade. Whatever it is, it's scary.
Kizmo
Thu Nov 24 2011, 07:01AM
First person arcing :) 80kVA from wall, no resonant cheating :p 12 BIG deshunted and unballasted mots in 3phase stack and rectified output. 30seconds of arcing and mots were smoking hot :)
