  • Guests: 61
question about the internal circuitry of a Flyback
Captain Proton
Sat Nov 19 2011, 11:14AM
Captain Proton Registered Member #3506 Joined: Sun Dec 12 2010, 02:48PM
Ash Small wrote ...
Patrick wrote ...
What is the silver cylinder thingie?
Capacitor?
(I did read recently that monitor flybacks have capacitors, and TV flybacks don't)
I am assuming that it's a capacitor judging on behaviour and looks..
Yeah you're right about that, i've also read that only Monitor flybacks have capacitor as a part of the internal rectifier circuitry, perhaps due to the higher operation frequencies.
Antonio
Sat Nov 19 2011, 01:07PM
The round thing is a capacitor. In most monitor flybacks there is a semi-cylindric part in the casing. The capacitor is inside. The other ground pins shall be connected to the ground pin, otherwise you have high-voltage loose inside the casing.
Sat Nov 19 2011, 01:41PM
Captain Proton wrote ...
Would it function as a voltage doubler in this configuration?
(presumably that long thing at the top is the diode, or is it a resistor?)
Sat Nov 19 2011, 02:22PM
I've found a single scrappy circuit diagram of a monitor LOPT, and it does indeed show an internal capacitor strapped across the focus output, presumably to reduce ripple and improve voltage regulation.
