  • Guests: 36
RoV IW3IPD (63)
01/13 si2030 (62)
ZVS
Platinum
Tue Nov 08 2011, 06:06PM Print
Is it possible to have a current adjustable zvs driver so you can vary current?
Tue Nov 08 2011, 06:51PM
The only way you can vary output current of this oscillator without changing component values, is to vary the input voltage. An other way of changing the current is eg. to change the capacitor value, for this you can connect several capacitor values to a rotary switch.
Forty
Wed Nov 09 2011, 04:47AM
A beefy variable inductor might work
Petezel
Thu Nov 10 2011, 10:12PM
Petezel Registered Member #211 Joined: Sun Feb 19 2006, 05:33PM
Okay I have one or two crude ideas for you:
Force the core into saturation by some means, or divert some of the power elsewhere, ie via a small winding into a dummy load resistor.
Alternatively, maybe wind two air core inductors in phase with the windings in series with the primary halves of the flyback. Use a slug core to vary the inductance, it should de-tune the oscillator enough to alter the output. You might lose some voltage this way too. Re-tuning the tank cap might bring the voltage back up, I don't know, I'm shooting in the dark somewhat here. I hope you figure something out and post the solution!
Platinum
Fri Nov 11 2011, 12:27AM
I'm not very good actually, I've had a ZVS driver built for me, but I cannot probably make one, maybe if I tried.
I've driven flybacks from small wallwort PSU's (phones, routers, etc the HF ones not iron) and comuter SMPS's and also halogen transformers which you can buy a 250W one for £12, I bought one before you can check my thread (halogen transformer flyback success)
But I cannot make circuits very well, I'm going to build a ZVS, but I don't know where to start, do I buy each part from the schematic? and do I need breadboard?
I would appreciate help!
Thanks.
Fri Nov 11 2011, 01:32AM
You don't need breadboard, you don't even need perf board or any of the other boards, some of the best ZVS drivers are just soldered together.
It may be easier to use a board for a first attempt, though.
Do you have a Maplin's near you? My local one has several different types of board in stock for a few quid each.
Ocean Waves
Fri Nov 11 2011, 06:15AM
Ocean Waves Registered Member #4181 Joined: Thu Nov 03 2011, 02:39PM
in all the ZVS arc videos that I have watched I don't recall one being made on anything more complex then ring board, usually a zvs is a trail of connected components strung across a half of a work bench... nothing holding them together but solder lol
Platinum
Fri Nov 11 2011, 04:46PM
I have a Maplins near, yes, but I have trouble understanding the ZVS schematic, so I think it'll be much easier on a breadboard, do I have to buy each single part for the driver?
Also I have nothing to solder with, I took the transformer out of my gun, and I'll be buying a good soldering station in a few weeks.
Alex M
Sat Nov 12 2011, 12:22AM
Platinum wrote ...
Here is a simplified graphical schematic of the ZVS driver
NiusB
1321057343 3943 FT127965 Niusb
Platinum
Sat Nov 12 2011, 01:21AM
That helps, thanks, the main components I need are the MOSFET's?
I can get these at ebay, they sell them.(£6 for 2)
I have a PSU from a PSU it is 12v @ 32A.
For the diode will these work
Thanks.
