  • Guests: 51
Fukushima
Sat Jan 25 2014, 12:07PM
Andy wrote ...
As Small, I think they meant, if you ingested radioactive substances, it would be best to drink, because most paths workout to your stuffed....
Well, I found this: Link2
"Antioxidant supplementation during radiation therapy poses a conundrum for the radiation oncologist, as antioxidants that protect normal cells from reactive oxygen species may provide the same benefits to cancer cells and reduce the efficacy of treatment. Short- and long-term injury to healthy cells, including tissue damage and increased risk of oncogenic transformation, can be prevented by antioxidants, as seen experimentally. New findings that antioxidants induce apoptosis in cancer cells and protect patients from painful side effects of radiation treatment may prove these compounds useful in future adjuvant therapy."
Which is 'sort of' relevant.
Sat Jan 25 2014, 02:03PM
Ash Small wrote ...
Andy wrote ...
At Fukushima, as at Chernobyl and Kyshtym, the big issue is not about acute exposure to radiation, but chronic internal expsoure by the ingestion of radionuclides, importantly caesium-137, strontium-90, and iodine-131. In this regard, data and observations derived from radiotherapay and X-radiography - short term acute exposure - is not especially helpful. When the machine is switched off, radiation exposure stops, and no more cells are damaged.
Ingested and inhaled material may be deposited or lodged in organs, bones, teeth, and lungs from where they bombard the surrounding tissue for years, and lifetimes. In 1963, it was discovered that in parts of the United States exposed to A-bomb fallout from the Nevada atomic tests 1945-1962, the level of Sr-90 in childrens' teeth was up to 50 times higher than control samples from areas far removed from fallout paths.
Radiation Countermeasures for Treatment of Internal Contamination
Mon Jan 27 2014, 12:23PM
Drones used to measure radiation in Fukushima nuclear plant - The Japan Daily Press Link2
Mon Jan 27 2014, 12:25PM
Fukushima town rejects hosting radioactive waste storage facility Link2
Tue Jan 28 2014, 10:36AM
Fukushima: The New Bot On The Block - Forbes Link2
Shrad
Tue Jan 28 2014, 11:52AM
Proud Mary wrote ...
It is operated using a remote control and unlike manned aircrafts, it has the option to fly lower, with a minimum of 300 meters in altitude.
why the heck don't they use a quadcopter or something like this to get closer and take real measurement ?
Tue Jan 28 2014, 12:29PM
Shrad wrote ...
I'm just guessing here, but would they require thick lead shielding to protect the electronics from the huge amounts of radiation present, thus making your average quad-copter too heavy to fly?
(just a wild guess)
Tue Jan 28 2014, 12:56PM
Ash Small wrote ...
Shrad wrote ...
(just a wild guess)
'Hardened' components and circuits capable of operating on the 'nuclear battelfield' are well understood and available, so I think it's more likely that costly drones which become contaminated - by the steam plume, for example - have to be written off, and taken to a radioactive waste dump, a place like the Chernobyl Graveyard which must exist at Fukushima, but of which pictures have yet to emerge. Keeping flying objects at a good height probably increases their service life, before it's off to the Graveyard you go.
Tue Jan 28 2014, 02:50PM
Ash Small wrote ...
Shrad wrote ...
(just a wild guess)
no. hardend semiconductors for military and spacecraft use are cheap and available. And the shielding of sensitive parts would be minimal. A tri-copter would be best, as quads are clearly for pansies. most of the cost is in instrumentation they would carry, the bots themselves are getting scary cheap... even a "single-flight-then-graveyard" cost would be cheaper than exposure for three humans and all its safety precuations.
besides there are tasks only humans can do, like turning a wrench on an important valve in some radioactive place. But no human should use up part of their lifetime exposure quota, doing something stupid like measuring a common radiation field. Any manager ordering a subordinate to do so, should be summarily executed, for crimes against humanity and good judgement.
Wed Jan 29 2014, 09:46AM
Fukushima ice wall: TEPCO drills freeze wells to stop contaminated groundwater Link2
