  • Guests: 54
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
How to increase the spark length of my tesla coil
Polonium210
Sat Nov 05 2011, 01:41AM
Polonium210 Registered Member #3450 Joined: Sun Nov 28 2010, 05:01AM
Electrikid221MnM wrote ...
are there any ways of making it work with a ssnst? Im limited when it comes to spending. im limited to the 99 dollar range
Not likely. Most turn themselves off if the load is anything other than a neon lamp. eBay has several OBIT's for a reasonable price. Search "ignition transformer". They look like this:
Sat Nov 05 2011, 10:32AM
Hi,
well, my best bet on using a SSNST would be rectifying it and filtering it soemhow (might be tricky, would probably need to charge the filter cap over a resistor which you short out later) and then using this for a DC resonant charging system... but for a first coil this is way too complex and probably more expensive than just buying a new nst. And in the end the nst might end up turning off from the interference of the coil no matter what you do!
From other side, flybacks, ignition coils and even most of driver components might be available to you almost for free, so it's on you whether you want to choose a spending curve or learning curve there. Iron power supplies for TC's are going to cost $$ no matter what you do, and shipping from ebay will be expensive.
If you can find any neon sign shops around you might get lucky to get some transformers far cheaper than that.
Electrikid221MnM
Sat Nov 05 2011, 11:54AM
Electrikid221MnM Registered Member #4172 Joined: Sat Oct 29 2011, 05:57PM
now that i think about it i think i will go with a 555 flyback driver or the 2n3055 driver. i will also check for neon sign shops. ok thanks for your help.
Sat Nov 05 2011, 02:55PM
Hi electrikid,
don't waste your time with 2N3055's and NE555's, as in short they suck. The "mazzili" flyback driver is about the same complexity as the 2N3055 one with collosally better results.
Electrikid221MnM
Sat Nov 05 2011, 03:11PM
ok ill try it
teravolt
Sun Nov 06 2011, 01:25AM
hear is a exalent site for desription how to build
