  • Guests: 71
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
do I need high power schottky diodes for half bridge
Sun Oct 30 2011, 02:43PM
1200 volt diodes are not Schottky. The highest voltage Schottky diodes I've seen were 200 volts and they had a huge reverse leakage current. Normally Schottky diodes are not rated over 100 volts.
Daedronus
Sun Oct 30 2011, 04:10PM
"Since 2001 another important invention was presented by CREE (NC, USA): a silicon carbide (SiC) Schottky diode. SiC Schottky diodes have about 40 times lower reverse leakage current compared to silicon Schottky diodes. As of 2011, they are available from several manufacturers in variants up to 1700 V."
From Here
Sun Oct 30 2011, 06:29PM
Hmm, I did some search and found this : Link2
You can see the SiC schottky diodes have a way too high forward voltage drop for this application.
It also seems that SiC diodes are not very common, I have never seen or used one in real life.
Daedronus
Sun Oct 30 2011, 10:09PM
Fast 120A (2x60) 1200V diodes are common on ebay, I have a few of them and I kinda assume they are SiC
Not sure what they are suitable for.
Luceš
Mon Oct 31 2011, 01:29AM
Luceš Registered Member #4108 Joined: Sun Sept 25 2011, 11:43PM
Well I found it cheaper to buy some irfp260's than It would be to get screwed on some schottky diodes... NOW I CAN BUILD A FULL BRIDGE cheesey
MrMatt
Wed Nov 02 2011, 01:43AM
MrMatt Registered Member #4156 Joined: Fri Oct 21 2011, 05:19PM
how about a slightly more beefy FET, its not much more to get something like a IRFP4668, much less RDS on, as low a 8 milliohm Vs about 55 for the 260's , you pay a bit of a penalty on input capacitance, but I don't see that being a big issue,
all this is mute if you are getting a smoking deal for the 260's
Luceš
Thu Nov 03 2011, 12:13PM
You can't argue $2 a piece amazed
MrMatt
Thu Nov 03 2011, 05:46PM
nope, not at all
