  • Guests: 44
Primary, secondary, is it possible to have a Tertiary and a Quaternary coil?
Tetris
Thu Sept 15 2011, 12:04AM Print
Hypothetically could you have a transformer with a tertiary (I love pronouncing that word, it sounds like tushy LOL) coil or a quarternary coil? Even so, could you go infinitely up? Like Quintenary, Hexinary, Heptinary, Octinary, Noninary, Decinary and so on? If so, would the output of a hypothetical "tertiary coil" be the # of windings in the tertiary over the # of windings in the secondary and so on? I know that you'd need a VERY thin wire, but its hypothetical. :3 It's killing me to want to know that!
Turkey9
Thu Sept 15 2011, 12:34AM
Are you thinking concentric coils? For example a Tesla Coil with a third coil inside of the secondary coil?
I believe it would act the exact same way as a transformer with multiple secondaries. Transformers have more than one set of secondary windings all the time like the filament supply on a MOT. If you had the space, you could put an infinite number of separate windings on a transformer core witch would each get a portion of the energy of the primary. Of course, as you approached infinity, the power each coil could supply would go to zero.
the mad scientist
Thu Sept 15 2011, 12:44AM
the mad scientist Registered Member #3768 Joined: Tue Mar 22 2011, 12:46AM
hv chick i thought that before too
^_^ this weekend ill do an experiment to see if u can then ill answer back
the mad scientist
Thu Sept 15 2011, 01:22AM
i think she means to have another coil induced by the secondary and so on.
not from the primary
Dr. ISOTOP
Thu Sept 15 2011, 08:55AM
One word: saturation.
And you're going to have _serious_ arc-over and tuning issues with a triple Tesla coil; I'm not sure whether its even mathematically possible.
Shrad
Thu Sept 15 2011, 09:52AM
aren't those magnifiers? I think of a base fed tertiary in resonance with the secondary fres when you describe this
Inducktion
Thu Sept 15 2011, 10:49AM
I thought it was impossible to saturate "air"....
Saturation of air core transformer, really?
My one word is: Impedance matching (well those are two words cheesey )
Tertiary coils are used in "magnifiers". If you used a fourth coil, the impedance of its base compared to the output impedance of the tertiary coil would be so low that you won't get any output.
Dr. ISOTOP
Thu Sept 15 2011, 08:32PM
Dr. Kilovolt wrote ...
Oh, I was referring to cascaded iron/ferrite transformers.
Fri Sept 16 2011, 05:15PM
You can have a system, termed 'magnifier' where you feed a secondary with a relatively low number of turns (or more specifically designed to have a low impedance output, lots of current but only ~1-50kv of output voltage) and use that to 'base feed' a second resonator that is of more traditional dimensions. Google tesla magnifier and base fed vttc for more info on the math behind it.
You probably wouldn't get very far with a 4th or 5th coil, like Dr. Kilovolt mentioned it wouldn't be feasible/useful to design a system to work well with a 4th coil. You could probably get away with base feeding multiple tertiary resonators, so long as you are careful to design them to all have the same resonant frequency.
