  • Guests: 44
Active Capacitor Discharge Bleeder Circuits
sngecko
Mon Sept 12 2011, 01:17PM Print
sngecko Registered Member #3447 Joined: Fri Nov 26 2010, 11:10PM
I've about finished building a current regulated (2 x 0-80mA) 3kW, 20kV power supply to drive a yet-unbuilt CO2 laser head, and I have a quick question about the possibility of devising an active filter capacitor (25kV, 2uF poly) discharging circuit.
I was going to just use a 100M, 10W resistive bleeder, but I'd like to not have that continuous power drain (few watts) during operation.
Does anyone know of a method to begin draining the cap only at switch-off? This is a hobby project, but it isn't "hobby-quality" and all the parts are built into a 16U rack cabinet, so I'm not interested in damp wooden dowels and chicken-stick lever action stuff. smile
Also, the capacitor is a monster poly (scroll down to big red capacitor picture) and the top connector is just a copper plate with what looks like a connector nub, but the only way I can think to connect to it is with a battery terminal clamp. Has anyone dealt with mounting and connecting one of these big boys?
Mon Sept 12 2011, 01:35PM
Solenoid operated switch?
Solenoid holds switch open during operation, so 'fail' mode is 'closed'.
Pinky's Brain
Mon Sept 12 2011, 05:51PM
Switch into a LR series circuit (critically or over-damped, if for some reason you want to go faster put a flyby diode in parallel) so your switch doesn't arc so bad.
Mon Sept 12 2011, 07:03PM
sngecko wrote ...
Then do the right thing and avoid any electromechanical switching that you reasonably can in your safety circuits. If you strap a 300MΩ resistor across your 2uF cap, the five time constant periods needed to reduce the voltage across it to zero will take 50 minutes.
sngecko
Mon Sept 12 2011, 08:06PM
Once again, thanks Proud Mary. I guess I just needed someone to say that it's not a huge deal if it takes an hour to come does to safe voltage, as long I know that. I will do exactly as you suggest.
As for the form factor question, did anyone look at the picture of the capacitor? It stands pretty tall, has a stainless steel bottom (ground) with some tapped holes and a copper top with that nub. It was found in a dye laser, but I didn't get the mounting hardware... Has anyone seen one of these?
Mon Sept 12 2011, 08:52PM
sngecko wrote ...
Hot switching at 20kV would involve really costly vacuum or SF6 relays, and even if you had one I'd still advise strapping the hard-wired bleeder across it, lest it fail.
One time constant period for 300MΩ and 2μF comes out very nicely at 10 minutes, so after starting with 20 kV on your capacitor it will take half an hour to bring the voltage down to 1 kV, forty minutes to bring it down to 400V, and fifty minutes to bring it down to 200V. I'd guess in practice it will decay just a bit faster due to the various leakage paths the electrons may be able to discover, and so make their getaway! smile
I'd suggest sticking an orange hazard sign on the back of the case saying that it must be disconnected from the supply at the wall for 60 minutes before opening.
Mon Sept 12 2011, 09:46PM
Might I suggest here, that, as usual, PM's advice is excellent as a failsafe, but also having a solenoid switched resistor of a lower value that 'fails' in 'safe' mode would significantly decrease discharge time.
If properly designed it would be incapable of 'jamming open'. (and I was answering your original question).
I'm sure everyone here would agree that, when it comes to safety, a backup is 'always' required.
Even with two safety systems, you still want the 'don't open for an hour' sticker, and you want to check that both systems still function on a regular basis.
(Leave it for an hour, then open it and check the function of both systems with the 'main circuit' isolated. This is probably the most sensible post I've made today smile )
Mon Sept 12 2011, 10:37PM
Sixty minutes is the perfect time to make a pot of tea and a bacon sandwich and have a read of the paper.
Xray
Tue Sept 13 2011, 04:19PM
What I have done for my 4KV power supply (used for magnetic impulse experiments) is I placed a standard neon bulb (the ubiquitous NE2) in series with my bleeder resitor. That way, I can visually see that there is lethal voltage in my caps. The lamp will go out when the voltage gets below abour 85 volts (varies slightly with each neon bulb). If you decide to use this scheme, make sure that the bleeder resistor value, and the peak DC voltage on your caps, doesn't excede the current capabilities of the lamp.
sngecko
Tue Sept 13 2011, 05:42PM
That's a good idea. Maybe I can work that into the instrument panel on the rack. Along with a sign that reads, "When this lamp is on, disassembly will result in a painful death."
