  • Guests: 15
Ivan Kalafatic (17)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
Where to buy primary windings?
atemporal
Wed Aug 31 2011, 08:04PM Print
atemporal Registered Member #4082 Joined: Wed Aug 31 2011, 07:57PM
hello everyone,
logistical question with regards to building my first coil. where exactly does one buy 150' of 1/4 " copper tubing. of course, just due to metal value it will be expensive, but i cant seem to find it online anywhere for ANY price. so where can i buy such a thing, or if i cannot, what are acceptable methods of joining shorter lengths of tubing to produce one?
Herr Zapp
Wed Aug 31 2011, 08:57PM
atemporal -
Something must have jumped the tracks here ...... whatever would you need 150 feet (did I read that right??) of 1/4" copper tubing for?
Do you have your coil completely designed (using TC design software like JAVATC or WINTESLA) so you know exactly how much primary inductance you need, and therefore how much copper tubing you need for your primary?
A correctly-designed small-to-midsize spark gap TC will require no more than 50' of 1/4" tubing for the primary.
Please post your entire set of design parameters here for review (the JAVATC or WINTESLA data file).
Herr Zapp
atemporal
Wed Aug 31 2011, 09:19PM
i was attempting to design from scratch, but upon using javatc, i came up with about 75' of tubing, which can be obtained. guess i just needed to swallow my pride and bow to superior knowledge.
Herr Zapp
Wed Aug 31 2011, 11:07PM
atemporal -
There is no "designing from scratch". To obtain resonance, the inductance and capacitance values of both primary and secondary circuits MUST be determined and then achieved in your construction.
75' of primary tubing is still way off base. Please post your JAVATC file so we can understand what you are trying to build, and the forum will critique your design before you go off on a painful tangent.
Make sure you fully understand Tesla coil theory of operation and standard construction practices before you start blindly buying component parts. Still the world's best single source of technical information on TC design and operation is Richie Burnett's site at: Link2
At an absolute minimum you need to understand primary/secondary resonance, quenching, resonant rise, coupling, spark gap operation and "tuning" before you try to finalize a "design".
Herr Zapp
atemporal
Wed Aug 31 2011, 11:28PM
by "designing from scratch" i meant running the necessary numbers and calculations independantly, and not in any combined calculator. i understand lc resonance, power factor correction, spark gap operation, capacitor spec, ect. i just wasn't able to optmize the dimensions of the primary coil, and thats where a little digital help came in. JAVATC did little to change any other specs in my design which strongly suggests i wasnt too off base.
heres the readout from JAVATC just to back this up:
J A V A T C version 12.5 - CONSOLIDATED OUTPUT
Wed Aug 31 17:12:04 2011
Units = Inches
Ambient Temp = 68°F
Surrounding Inputs:
0 = Ground Plane Radius
0 = Wall Radius
0 = Ceiling Height
Secondary Coil Inputs:
Current Profile = G.PROFILE_LOADED
3 = Radius 1
3 = Radius 2
3 = Height 1
36 = Height 2
1120 = Turns
22 = Wire Awg
Primary Coil Inputs:
Round Primary Conductor
3 = Radius 1
12.736 = Radius 2
0.25 = Height 1
0.25 = Height 2
17.8501 = Turns
0.24 = Wire Diameter
0 = Ribbon Width
0 = Ribbon Thickness
0.0112 = Primary Cap (uF)
3 = Total Lead Length
0.125 = Lead Diameter
Top Load Inputs:
Toroid #1: minor=6, major=36, height=36, topload
Secondary Outputs:
140.02 kHz = Secondary Resonant Frequency
90 deg° = Angle of Secondary
33 inch = Length of Winding
33.9 inch = Turns Per Unit
0.00412 inch = Space Between Turns (edge to edge)
1759.3 ft = Length of Wire
5.5:1 = H/D Aspect Ratio
28.1686 Ohms = DC Resistance
28842 Ohms = Reactance at Resonance
3.42 lbs = Weight of Wire
32.783 mH = Les-Effective Series Inductance
33.169 mH = Lee-Equivalent Energy Inductance
32.022 mH = Ldc-Low Frequency Inductance
39.41 pF = Ces-Effective Shunt Capacitance
38.952 pF = Cee-Equivalent Energy Capacitance
52.961 pF = Cdc-Low Frequency Capacitance
7.96 mils = Skin Depth
34.294 pF = Topload Effective Capacitance
92.0132 Ohms = Effective AC Resistance
313 = Q
Primary Outputs:
140.03 kHz = Primary Resonant Frequency
0.01 % = Percent Detuned
0 deg° = Angle of Primary
73.54 ft = Length of Wire
13.24 mOhms = DC Resistance
0.305 inch = Average spacing between turns (edge to edge)
2.617 inch = Proximity between coils
0 inch = Recommended minimum proximity between coils
115.678 µH = Ldc-Low Frequency Inductance
0.01119 µF = Cap size needed with Primary L (reference)
0.058 µH = Lead Length Inductance
160.119 µH = Lm-Mutual Inductance
0.083 k = Coupling Coefficient
0.135 k = Recommended Coupling Coefficient
12.05 = Number of half cycles for energy transfer at K
42.83 µs = Time for total energy transfer (ideal quench time)
Transformer Inputs:
110 [volts] = Transformer Rated Input Voltage
15000 [volts] = Transformer Rated Output Voltage
60 [mA] = Transformer Rated Output Current
60 [Hz] = Mains Frequency
110 [volts] = Transformer Applied Voltage
0 [amps] = Transformer Ballast Current
0 [ohms] = Measured Primary Resistance
0 [ohms] = Measured Secondary Resistance
Transformer Outputs:
900 [volt*amps] = Rated Transformer VA
250000 [ohms] = Transformer Impedence
15000 [rms volts] = Effective Output Voltage
8.18 [rms amps] = Effective Transformer Primary Current
0.06 [rms amps] = Effective Transformer Secondary Current
900 [volt*amps] = Effective Input VA
0.0106 [uF] = Resonant Cap Size
0.0159 [uF] = Static gap LTR Cap Size
0.0277 [uF] = SRSG LTR Cap Size
197 [uF] = Power Factor Cap Size
21213 [peak volts] = Voltage Across Cap
53033 [peak volts] = Recommended Cap Voltage Rating
2.52 [joules] = Primary Cap Energy
209.1 [peak amps] = Primary Instantaneous Current
43.4 [inch] = Spark Length (JF equation using Resonance Research Corp. factors)
12.4 [peak amps] = Sec Base Current
Rotary Spark Gap Inputs:
0 = Number of Stationary Gaps
0 = Number of Rotating Electrodes
0 [rpm] = Disc RPM
0 = Rotating Electrode Diameter
0 = Stationary Electrode Diameter
0 = Rotating Path Diameter
Rotary Spark Gap Outputs:
0 = Presentations Per Revolution
0 [BPS] = Breaks Per Second
0 [mph] = Rotational Speed
0 [ms] = RSG Firing Rate
0 [ms] = Time for Capacitor to Fully Charge
0 = Time Constant at Gap Conduction
0 [µs] = Electrode Mechanical Dwell Time
0 [%] = Percent Cp Charged When Gap Fires
0 [peak volts] = Effective Cap Voltage
0 [joules] = Effective Cap Energy
0 [peak volts] = Terminal Voltage
0 [power] = Energy Across Gap
0 [inch] = RSG Spark Length (using energy equation)
Static Spark Gap Inputs:
8 = Number of Electrodes
0.125 [inch] = Electrode Diameter
0.524 [inch] = Total Gap Spacing
Static Spark Gap Outputs:
0.075 [inch] = Gap Spacing Between Each Electrode
21213 [peak volts] = Charging Voltage
21203 [peak volts] = Arc Voltage
31862 [volts] = Voltage Gradient at Electrode
40465 [volts/inch] = Arc Voltage per unit
100 [%] = Percent Cp Charged When Gap Fires
5.654 [ms] = Time To Arc Voltage
177 [BPS] = Breaks Per Second
2.52 [joules] = Effective Cap Energy
359542 [peak volts] = Terminal Voltage
445 [power] = Energy Across Gap
47.8 [inch] = Static Gap Spark Length (using energy equation)
Herr Zapp
Thu Sept 01 2011, 01:47AM
atemporal -
OK, you're on the right track now. When you start out asking about a 150' primary conductor for a small/medium coil, it gives the initial impression that something is amiss.
Use JAVATC to run alternate scenarios. Your 6" X 36" toroidal topload is a little disproportionate for a 6" diameter secondary, so try reducing that to something like 6" X 24" or 6" X 30" and see what happens to your primary conductor length. Then, try increasing your tank cap value to .018 or .02uF. Your coupling coefficient could be increased slightly, or better yet design the mechanics of the system so you can adjust the relative height of the primary/secondary to allow adjustment of K. Do you have adequate spacing between the OD of the secondary and the ID of the primary? You'll probably want at least 1" with a 15KV power supply.
Herr Zapp
atemporal
Thu Sept 01 2011, 03:22AM
OK changed toroid to 24", and MMC value to 0.02 uF, and get a much more reasonable value of 40' of wire needed. my question is, how much voltage overhead should my MMC really need? to provide the necessary capacitance using the best caps i could find (cornell dubilier 942C20P15K-F) to get the recommended ratings for voltage (53KV) and capacitance (0.02uF), i would need quite a few capacitors, and that would also be quite expensive. is there also some way to optimize the MMC to use less caps, or are there larger, better high-voltage caps i just haven't found yet? getting slightly off topic, but any help would be appreciated.
heres the new JAVATC log:
Wed Aug 31 22:56:09 2011
Units = Inches
Ambient Temp = 68°F
Surrounding Inputs:
0 = Wall Radius
0 = Ceiling Height
3 = Radius 1
3 = Radius 2
3 = Height 1
36 = Height 2
1120 = Turns
22 = Wire Awg
4 = Radius 1
11.214 = Radius 2
0 = Height 1
0 = Height 2
10.4934 = Turns
0.25 = Wire Diameter
0 = Ribbon Width
0.02 = Primary Cap (uF)
6 = Total Lead Length
Top Load Inputs:
Toroid #1: minor=6, major=24, height=36, topload
Secondary Outputs:
168.19 kHz = Secondary Resonant Frequency
33698 Ohms = Reactance at Resonance
31.888 mH = Les-Effective Series Inductance
33.056 mH = Lee-Equivalent Energy Inductance
28.081 pF = Ces-Effective Shunt Capacitance
27.089 pF = Cee-Equivalent Energy Capacitance
41.849 pF = Cdc-Low Frequency Capacitance
7.27 mils = Skin Depth
22.764 pF = Topload Effective Capacitance
101.075 Ohms = Effective AC Resistance
333 = Q
Primary Outputs:
168.19 kHz = Primary Resonant Frequency
0 % = Percent Detuned
41.8 ft = Length of Wire
6.94 mOhms = DC Resistance
0.438 inch = Average spacing between turns (edge to edge)
3.025 inch = Proximity between coils
44.801 µH = Ldc-Low Frequency Inductance
0.02001 µF = Cap size needed with Primary L (reference)
0.138 µH = Lead Length Inductance
91.43 µH = Lm-Mutual Inductance
0.076 k = Coupling Coefficient
13.16 = Number of half cycles for energy transfer at K
38.97 µs = Time for total energy transfer (ideal quench time)
Transformer Inputs:
4.5 [joules] = Primary Cap Energy
449 [peak amps] = Primary Instantaneous Current
16.8 [peak amps] = Sec Base Current
0 [rpm] = Disc RPM
18.437 [ms] = Time To Arc Voltage
54 [BPS] = Breaks Per Second
4.5 [joules] = Effective Cap Energy
576135 [peak volts] = Terminal Voltage
244 [power] = Energy Across Gap
43.2 [inch] = Static Gap Spark Length (using energy equation)
Herr Zapp
Thu Sept 01 2011, 06:50AM
atemporal -
For a fairly reliable MMC assembled from the C-D 942C20P15K, you'll need around 40 caps - 2 parallel strings of 20 each. These caps are very reliable in TC service when the MMC is conservatively designed for both peak voltage and peak current. Alternatives are capacitors with low-loss dielectrics specifically designed for high-current, high frequency service. New, these are much more expensive than an MMC. Surplus caps from medical or industrial laser systems, ex-military radar systems, RF induction heating systems, etc. can be used, but if you don't know their prior history you don't know how much service life is left.
Three strings of 22 of the C-D caps will give you .02uF at 44KV, which should give very long life in your coil if you maintain a reasonable spark gap breakdown voltage. Go to the C-D website and use the "Part Search" function to check distributor stock. Right now, DigiKey, Richardson, Allied, Waldom, and TTI show stock. Contact these distributors to find your best pricing (Richardson is showing $3.63 each in quantities of 50).
Herr Zapp
atemporal
Thu Sept 01 2011, 04:00PM
yeah, its about what i was afraid of, expensive no matter what you do. thanks for all the help Herr Zapp, i think i have a final design, and JAVATC predicts 43" sparks ;)
