  • Guests: 55
Selling Nixie Clocks
Inducktion
Mon Sept 26 2011, 02:05AM
Well, you could also implement it using one of those LED dimmer circuits using a 555 timer as well, I think. Just use one color then! You could probably try to use two driving one string of LED's, making a sort of pulsey look to them. It would be really neat!
doctor electrons
Mon Sept 26 2011, 10:45PM
doctor electrons Registered Member #2390 Joined: Sat Sept 26 2009, 02:04PM
This may help you out!
The leads on the in-16 are "fly leads" not solid pins. If your circuit board holes are close to the tube
diameter then it should work just fine. Remember the bigger the diameter "of the hole pattern" the higher
the tube will need to sit above the board to accommodate the bend needed to hit the holes.
1317077159 2390 FT123292 In16 Diagram
Edit: Those are millimeters by the way! I wish they were in inches but sadly, they're not....
Nicko
Tue Sept 27 2011, 02:46PM
magnet18 wrote ...
So does anyone know how far apart the pins are?
(i need to learn russian :P)
You can get a pretty reasonable translation via Google Translate - I use a Russian Alphabet site to bang in the characters and Google does an OK job...
Stolen from Dieter's site:
Pinout
magnet18
Tue Sept 27 2011, 04:52PM
so it's about 8mm then?
that seems really small...
doctor electrons
Tue Sept 27 2011, 09:21PM
That seems right, in the drawing i gave you the whole tube diameter is only 13 mm.
These tubes are sometimes called "mini". Still very cool tubes though, very warm glow and good color!
magnet18
Wed Sept 28 2011, 03:38AM
Right then, I made the alternate part in eagle that can fit both tubes, did some fancy pin/pad connection to get everything working right, and am almost 4/5 of the way through a total schematic revision, I had to break the one giant schematic up into 5 little modules (power, seconds, minutes, hours, logic), mainly to comply with eagles size limit and also because it's not a bad idea in general. All the sections will be connected by 10 or 16 pin ribbon cable. Things being panel mounted to the front (indicator LED, rotary switches, power switch) will have to be point to point wired to the board.
Schematic (not broken up) available here- Link2
magnet18
Sat Oct 01 2011, 02:54AM
I have attached my project file. It has the .sch's, .brd's, and .pro's (whatever those are)
Any questions, comments, concerns?
]nixie_clock.zip[/file]
Sat Oct 01 2011, 10:22AM
I found a nice chip on Supertex, its a 32 channel HV driver.
Works out about $4.25 so not bad at all, as long as you have SMD reflow-fu.
Kind regards, -A
