  • Guests: 50
Selling Nixie Clocks
magnet18
Wed Aug 31 2011, 10:49AM
The problem with making only one is that it costs $115 to make 1 pcb, and $135 to make 20
I might try making one at home myself...
as for noise, I was using a dedicated 555 smps (2 actually, to keep current down) with some epic decoupling between it and the logic side of things, it was working well on the perfboard prototype, laid out the same.
The tubes are IN-14's
Nicko
Wed Aug 31 2011, 01:13PM
magnet18 wrote ...
Hmm. That's very expensive for a prototype board - in Europe, we have houses like Olimex which charge about 30 euros for a 10cm x 16cm double-sided, plated through, silk screened & soldermasked panel (which they panellize FOC) - I'm certain there are similar services in the USA, however, I take your point.
If you can make one first, it might save a whole lot of grief later on, apart from just being good engineering practice smile Just because something works on a breadboard doesn't guarantee it'll be fine on a given PCB, especially when you are switching significant currents (an amp or so) - also, unless you 'scope the power & data, you won't see how close to the boundaries you are regarding spurious resets etc. Decoupling generally is on the Vcc lines - SMPS noise can quite happily inject itself via the ground return/plane as well which any amount of decoupling will not stop and which is largely dependant on layout - these sorts of problems can be intermittent & very subtle. Building something for sale is not the same as building it for yourself.
There is a page on my site about nixie power supplies - although you are using a 555-based system, the points about the design of the ground plane & return still apply - Link2
IN-14s are a nice tube, but have the "upside down 2" instead of a "5" - no-one seems to know why the Reflector factory did this - it can hardly have saved them much money. IN-16s are a bit smaller but have a dedicated "5" - also a nice tube - the "2" vs. "5" is a personal thing...
It maybe that you'll have absolutely no problems at all, but if you are selling stuff, doing the basics of a real prototype test is not just good engineering practice, its good for business...
doctor electrons
Wed Aug 31 2011, 09:20PM
doctor electrons Registered Member #2390 Joined: Sat Sept 26 2009, 02:04PM
Cant wait! Your plan sounds pretty solid! Usually thats the hardest part of starting up a biz.
Who knows, maybe you will sell a ton of them. Heres a few ideas that may help!
1) Be creative with the case, its gotta be cool. Possibly led illuminated.
2) Use matched, good bright tubes, previously mentioned no upside-down 2's that'll kill any clock!!
3) Bigger is better when it comes to the tubes!
4) Make sure to have colon indicators, people just love those. Some even gut a purchased clock just to add them!
5) Make yourself proud!!
Good luck! Im on the list! ;)
magnet18
Thu Sept 01 2011, 02:25AM
jeez, I guess I'll sell it with the option of IN-14's or IN-16's, don't know why you guys are so touchy about that 5 issue tongue
and yes, the colon is obligatory smile
doctor electrons
Thu Sept 01 2011, 11:18PM
LOL!! Us Nixie fans are a little picky i guess!!
As far as the colon indicators go, i have seen clocks with little glass test tubes over each
pair to protect them and allow you to clean them as well.... (thats another little hint)
I am excited to see what you come up with!!!!
magnet18
Fri Sept 02 2011, 02:41AM
if it helps stave your curiosity, it will have silver hammered paint, blue backlighting, and chickenhead knobs
first, I must finish the tesla coil, and maybe build a website
magnet18
Sun Sept 25 2011, 03:20AM
Does anyone happen to know what the diameter of the circle the pins on the bottom of a IN-16 forms? I can't seem to find it :P
Inducktion
Sun Sept 25 2011, 04:05AM
Oh, as a suggestion, why not make it so the colors of the backlight gradually change around, like those color changing light bulbs? That would be neat to see.
Sun Sept 25 2011, 05:53AM
I built a nixie tube clock some time ago, but I hardly ever use it as its "hard" to use.
I manually have to set the time, its a drag so I don't do it. Why do I have to set the time so often, because I do not wan't to let it burn when I am not home.
It's not that I don't trust my own design, but there is just no insurance covering if my home made electronics burned down my apartment, please consider and investigate the laws and rules on what have to be done in order to start selling electronics.
The rules might be different where you live, but it got to a point for me where I have given up trying to sell finished products due to I could be sued into bankruptcy.
magnet18
Mon Sept 26 2011, 12:42AM
@Inducktion, I like the idea, but that is a lot of circuitry since I'm not doing this with a uC
@Mads, I think things are a bit looser over here, but I'll definitely check, thanks for the warning
So does anyone know how far apart the pins are?
(i need to learn russian :P)
