  • Guests: 30
rev (49)
Cheech707 (35)
M_Gargantua (35)
nyditch (39)
07/21 Gagazet (33)
07/21 Chris Cristini (36)
07/22 Reaching (40)
Anyone here tried Arc Sintering oxides?
Carbon_Rod
Mon Aug 08 2011, 02:31AM Print
I found a partial paper hidden behind a pay-wall that ambiguously cites an experiment with Ferric oxide (5->20A @ 200Hz), but it did not give the authors to search at my library. X-D
Has anyone tried this with other oxides?
(I'm trying to avoid galvanized or stainless steel's toxic off gassing)
Cheers,
Mon Aug 08 2011, 06:16AM
Hm. I found Link2 which if you ignore the pseudoscientific rubbish does contain useful information on underwater plasma arcs.
Maybe useful?
I have tried to use arc sintering to make glow in the dark compounds for use as EL phosphor but it didn't work.
What is interesting though is that potentially you could use a somewhat conductive (i.e. bicarbonate) mixture to ignite a larger volume in a sealed tube..
the resultant high temperatures should be enough to sinter pretty much anything you can throw at it.
Carbon electrodes also work for this...
-A
Mon Aug 08 2011, 02:32PM
Perhaps you'll find some helpful ideas in this here paper:
Joanna R. Groza, Antonios Zavaliangos, Sintering activation by external electrical field Materials Science and Engineering A287 (2000) 171–177 Link2
Carbon_Rod
Thu Aug 11 2011, 03:29AM
Thanks for the tips,
but I am looking for process information similar to Spark Plasma Sintering of cemented carbides.
Cheers,
Rod
Selenite
Fri Aug 12 2011, 02:45AM
Selenite Registered Member #4046 Joined: Fri Aug 05 2011, 03:55AM
Here's some diy arc sintering of Ferric oxide(magnetite) with an arc welder for use in a chlorate cell:
