  • Guests: 67
IAmSpock (18)
01/30 Ian (37)
01/30 Lucas (40)
01/31 Mathias (42)
HV Flyback Bench Top Power Supply for Lab.
first  4 5 6 7
Pinky's Brain
Sun Jan 22 2012, 03:39AM
wrote ...
I want to use soft switching to reduce MOSFET heating. When i say ZVS/ZVC i dont mean a resonant circuit.
What ZVS/ZCS topologies don't use resonance to achieve it?
Sun Jan 22 2012, 07:25AM
maybe the "zero" part isnt fully right then.?
Tue Jan 31 2012, 12:26PM
Hold on to your hats folks! A new board will be etched shortly, with the following features:
-IGBT main switch, the HGTG7N60A4D in the TO-247 case.
-Current transformer (no more resistor losses), with Pulse-by-Pulse limit, to reduce IGBT murder rates.
-Waveform duty cycle will be variable from 0-90%, ill use the UC28023D2 ic.
-Input will be 70 Vdc at 3 amps average (140 Watts of output at 66% eff)
-Flyback freq will be upped from 17 kHz to 40 kHz.
Ive considered, but dont think ill use a wall socket rectified to 170 Vdc for ther primary... at least for now, as i have
pending lifter research and a busy class schedule.
first  4 5 6 7
