  • Guests: 31
01/13 si2030 (62)
Disc flyback
nOg
Sun Jul 24 2011, 05:02AM
nOg Registered Member #4011 Joined: Mon Jul 18 2011, 08:14AM
Hi Newton Brawn,
Yes, the Vladmiro Mazzilli schematic (sorry, incorrected typing). tongue
I just broke my bigest ferrite that I had. (left) cry
NEW one insteed of broken core. Look smaller. but weight is a litle bit looser.
1311482609 4011 FT120471 Sl730177
Here is my NEW ferrite core drawing.
1311482372 4011 FT120471 Sl730176
Can I repair the core?
Regards,
EDIT: The windor wider is 14mm.
In core drawing, pls cut ZERO off, I means 160=16mm, 100=10mm, 320=32mm
Forty
Sun Jul 24 2011, 05:52AM
yes. use cyanoacrylate superglue.
Sun Jul 24 2011, 06:15AM
nOg wrote ...
Regards,
yes, use super glue, since youll have a gap (0.02" to 0.050") in the core anyway, the tiny super-glued cracks wont matter much.
nOg
Sun Jul 24 2011, 01:30PM
Super glue. Great, I have.
So, what does the gap in core effect on transformer?
Pinky's Brain
Sun Jul 24 2011, 01:58PM
AFAIK, in a true flyback the gap is there to increases energy storage. In a push/pull setup it gives you a little more margin for error with flux walking.
Newton Brawn
Sun Jul 24 2011, 02:56PM
nOq
Yes, you can repair the ferrite core with superglue. No electrical-magnetic problems.
In your Mazzilli or other push pull converter, the air gap do not help, just is something that shall be avoided. However, in fly back converter the air gap is a requirement.
For Mazzzilli, make sure no air gap (or at least gap smaller than 0.05mm.).
It should be noted that some ferrite cores for fly back are manufactured with one leg 0.5~1.0 mm shorter than other 3 legs, in such way when the core is assembled the gap comes automatically .
I have cut 0.5-1.0 mm of the core leg in order equalize the lenght of legs, eliminating the gap. To grind use carbite sandpaper#100 (black one)
I think you need one ferrite core with bigger window to allow the assembly of the secondary coil. You can find a TV or monitor in the street or in the "Environmental Day Party " for free.
Regards
Newton
By the way, what kind of measuring unit did you use for the dimensions of you sketch ?? Shall I divide the dimensions by 10 to get the dimensions in MILIMETERS ??
I have tried to post a drawing as you have posted in above reply. No succes. Can you tell step by step the sequence to post a picture ?
Thanks
Newton
nOg
Sun Jul 24 2011, 04:20PM
Hi Newton Brawn,
Refer to your shemetic Link2 here.
I understand how important for inslutor over core. And what's necessary for Winding Form inslutor?
Thanks I'm going to tv repair shop tomorrow.
I can find the bigger window, 18mm at here. or Can I cut the core and glue it together?
Something like my drawing, should divide by 10.
For the post, I use Window Paint Programme, paste the picture that you want and add more another picture. Save at destop. Click at "attach file/image" below, insert your file and click at "Preview", So you can see your link.
Good luck
nOg
Mon Jul 25 2011, 04:09AM
Thank you for your answer.
New size of core.
1311563379 4011 FT120471 Sl730190
Hi New ton
It sounds that push pull converter is not suitable to make good ferrite transformer. Is it better to drive with GDT?
My GDT driver is very simple. Tl494 with 1:1:1 GDT. I ran DC flybacks. It's sitll ok but flybacks was very hot and damage even I put in transformer oil.
1311566813 4011 FT120471 Sl730174
Regards,
Newton Brawn
Mon Jul 25 2011, 04:39AM
nOq:
Thanks for the info re. posting a picture.
""" I understand how important for inslutor over core. And what's necessary for Winding Form inslutor? ""
To built the Winding Form Insulator, you need to make mandril (cilinder )18mm diameter x 13mm long . It coulde be a piece of wood, plastic or just cardboard/ masking tape cilinder.
1- cut a polyester ribow 13.2 mmX400mm, EDITED
2-apply a thin layer of epoxi on one face of the ribow,
3-coil (wind) the ribow over the mandril,
4- secure the ribow with 2~3 turns of wire #30 awg,
5 - remove the mandril, leave the epoxi dry for 1 day,
6- remove the wire .
From your second core sketch I am assuming that the window area (space for the secondary coil) is 18mm x 52mm. Please confirn.
If the window area is 18x52, we do not have space to house a 660 turns coil. The secondary shall be modified tobe constructed with 2 coils of 330 turn each.
The core at Mazzilli drive gets hot because the ferrite core works in the extreme of saturation. It shall be on for sort time only.
One way of reduce (but no eliminate) the core heating is increasthe value of the 47-200uH choque. Preference for air core choque. To solve this problem, the gates can be driven by a small ferrite beat 1:1:1 turn ratio. In this way, the main core works bellow the saturation (0.3T) and the small ferrite core saturate a lower current, providind the required feedback to the gates .
Next week I will be travelling no communication...
Regards
Newton
nOg
Mon Jul 25 2011, 07:15AM
Yes, my window is 18x52mm.
Thanks for your help.
and enjoy your trip.
nOg
