  • Guests: 52
Post your biggest easy mistake here...
vk2fro
Fri Jul 01 2011, 05:44AM
vk2fro Registered Member #3930 Joined: Sun Jun 05 2011, 07:27PM
Light chaser circuit. 3 channels, different patterns, quite a few IC's, driving those 100-150 watt mains floodlights as disco lights.
During faultfinding a tired me forgot to unplug as I went to solder a setting jumper in place. Just about every semiconductor on the PCB exploded as mains electricity made a run for the earthed soldering tip (and here in australia its 240V mains).
Of course I copped a few shrapnel scratches, and my ears were ringing for a while, but thank god I was wearing saftey glasses!
Stunk my bedroom out too - fried IC's really tend to stink.
Tue Jul 05 2011, 08:13PM
Yesterday i found out i had the control grid and suppressor grid on my GU-81M mixed up... For a year and a half!
(I meant it when i said that belonged here in that thread!)
Forty
Wed Jul 06 2011, 04:03AM
as i was reading arcstarters post, i just noticed something i must of done earlier: i guess i was soldering over my breadboard and dropped some solder on it. i'll never be able to use hole G-63 again.
Jrz126
Wed Jul 06 2011, 11:44AM
Jrz126 Registered Member #242 Joined: Thu Feb 23 2006, 11:37PM
Was building an inverted pendulum for my advanced digital circuits final project. It was a bit of a scramble, had to build everything from scratch, and only ~2 weeks to do it.
We just got the motor to start turning with a simple PI regulator, we were watching the pendulum move, then it suddenly stopped. Look over at the breadboard to see the little cat-5 jumper wires glowing red hot. Both fets shorted in a leg, shorting out the ~45Vdc.
Burnt Bread Board
the +/- strip is shorted, and all the melted sections made a good portion of the breadboard unusable.
Using a fuse could have prevented this. Although I probably would have run out of good fuses and had to wrap it with AL foil.
Forty
Wed Jul 06 2011, 07:35PM
just made over 50ft of litz wire to use for a transformer, but i don't have a core big enough to fit 90+ turns on.
well except for a giant toroid, are toroidal transformers any good?
Inducktion
Wed Jul 06 2011, 11:49PM
Forty wrote ...
Torodial transformers work fine ^^
Hon1nbo
Thu Jul 07 2011, 01:53AM
I was testing my underwater ROV's electronic controls on dry land before water tests, (seen in the project section) and I got a phone call. Instead of turning the power switch (which used a key hence any thought at all), I took the call and came back, after realizing it had been twenty minutes, to a ruined 1000 GPH Bilge Pump from running it dry for a long time. I also depleted my already very low SLA to the point where I never did get a good charge out of it again, so I had to get a new battery
Lesson learned, but the project is going to get a complete overhaul once I can fund it, maybe my university will or I could get a local defense contractor to sponsor it like they did the last ROV the school had.
-Jimmy
magnet18
Sun Jul 10 2011, 06:55PM
I spent an entire weekend trying to build plasma speakers until I realized I was using TL071's instead of 555's
*FACEPALM
quicksilver
Mon Jul 11 2011, 08:20PM
Bringing a very nice guitar to a party where there was drinking going on and I left to use the bathroom.
Chip Fixes
Mon Jul 11 2011, 11:00PM
Chip Fixes Registered Member #3781 Joined: Sat Mar 26 2011, 02:25AM
quicksilver wrote ...
haha, are the pictures too gruesome to show?
