  • Guests: 53
classic 4046 PLL tesla coil tips
Shrad
Mon Jun 13 2011, 08:28PM
still not
I'll need to mount my variac and slowly ramp voltage to see what's going on
the pity is I think I have an issue with my PLL, I can't get the small streamers back with a single switch...
Tue Jun 14 2011, 02:41AM
Shrad wrote ...
still not
Gah, PLLs are always a pain in the ass tongue. If you have a scope with 2 channels/probes, you should probably try to tune the phase (the pot on the VCO if you use the same kind of schematic i am used to). If you are running your secondary out of phase... Well, i think i need not explain.
Daniel Kramnik
Tue Jun 14 2011, 03:01AM
Daniel Kramnik Registered Member #3885 Joined: Sun May 15 2011, 12:47AM
Do you have insulating pads between your transistors and heatsinks? I can't quite tell from the pictures. If not, then that would definitely prevent the bridge from functioning. Try switching to two separate heatsinks without insulating pads to get better thermal performance without shorting the MOSFETs' drains.
What type of diodes are you using in your bridge? Are you sure that they are ultra fast recovery diodes rated to withstand the voltage and current that you will be putting through them? I use MUR860 in my SSTC.
If it still doesn't work, then the best course of action would probably be to rig up a super simple 74HC14 antenna feedback driver just to test the bridge. That way, you could narrow down the problem to either the bridge or the PLL.
Dr Hankenstein
Tue Jun 14 2011, 06:27AM
Dr Hankenstein Registered Member #1642 Joined: Sun Aug 17 2008, 11:36PM
Here's some reading up you may want to do on the 4046 in this article. At least this is how I approached my project and tuning the PLL: Link2 Good luck, Hank
Shrad
Tue Jun 14 2011, 09:26AM
Thanks Dr
I had forgotten that website and it sure is a nice ressource... I think I'll redesign my PLL driver and bridge based on more resources and readings
The understanding of the 4046 is indeed the key to success I think, and I need more tweaking points in order to tune it to the best
as for heatsinks and mosfets/igbts, I use a single heatsink but it has top quality insulator pads with arctic silver between each interface
diodes are ultra fast schottky rectifiers (20 or 40ns, I dont recall well) rated 400V 16A in a TO220 body (have a tray of them bought 5€ at a flea market)
Now the thing to do is read about that 4046 more deeply, and design something more flexible (I was thinking the simpler the better, but it's not always the case)
I will also have some read about coupling and primary positioning, as I believe the more coupled the better with these kind of coils
I have hope, because at 200VDC, just before the single switch popped, the streamers were 1 inch or something of very nice purple swords
EDIT: it seems, by that failure, that the PLL was in fact locked on an harmonic, why I had moderate breakout and instant destruction of the bridge
I'll make another driver with plenty of test points, and SMD layout to get better repartition of the components
Inducktion
Tue Jun 14 2011, 08:04PM
I thought Schottky's had no reverse recovery time...
Wed Jun 15 2011, 01:41AM
Inducktion wrote ...
I think he me have mistaken it for a schottky or something, because schottky diodes are rarely 400v. The highest i have seen is 200, unless they are silicon carbide.
Shrad
Thu Jun 16 2011, 08:56PM
sorry, you are right
I either misread a datasheet or read a bugged one as they are 100V ones
data: Link2
I'll have to find some better diodes
I won't have much time this next month to work on my coil as I'll be very busy at work (at least two week of work 3 hours away from home, lodging there etc..)
