  • Guests: 91
Strange observations with application of high voltage to 25 watt light bulb
Nah
Thu Jun 09 2011, 07:25PM Print
Hello!
A 10kilovolt, 23 miliamp AC voltage source was applied to a 25 watt, incandensent lightbulb. The filliment inside started vibrating at a very fast rate. Any opinions on why this is happining? I have some ideas, but I want to see what our members have in mind.
Thank you
Paul
radiotech
Thu Jun 09 2011, 08:45PM
To start off: What is the frequency?, Was the current 0.023 A through the filament. If it was , for a 25 watt 120 volt lamp, there would have been
13 volts across it, enough for a feeble glow in a dark room.
From there, what was geometry of filament?
Forces? Earth Bfield? 1/4 gauss. Skin effect thermals?
What filler gas if any?
Precise waveform of the voltage as measured at lamp terminals?]
Nah
Thu Jun 09 2011, 09:40PM
60hz
half of the output was grounded.
filiment was in a rectangular form
I don't think that you need that much info, are you pulling my leg?
Normal light bulbs are argon filled, if I remember
JKowalski
Thu Jun 09 2011, 11:32PM
JKowalski Registered Member #3595 Joined: Mon Jan 10 2011, 04:46AM
I would think it would be ion wind - the trace gases in the bulb are being ionized and the spring-ish filament is being repelled from these gases... The spring action of the filament establishes some resonance over time...
Xray
Fri Jun 10 2011, 12:20AM
Nah wrote ...
Hello!
Thank you
Paul
You need to give more details. When you state: A 10kilovolt, 23 miliamp AC voltage source was applied to a 25 watt, incandensent lightbulb. What do you mean by "applied"? Was it across the filament, or did you simply connect one terminal of the transformer to one filament contact, so that the gas inside the bulb could ionize through capacitive coupling with the surrounding air? Also, was it a frosted or clear lightbulb? Others may want to attempt to duplicate what you did, and so every detail is important.
Nah
Fri Jun 10 2011, 07:58PM
One terminal was conected to one side to the light bulb, the other to ground.
Clear light bulb, if it was frosted, I couldn't have see the filiment!
I think j is spot on with the ionic wind thing, that was my theory.
On the other side, my transformer burnt out rolleyes
However, it is the older, non potted type, so I think I can repair it.
Fri Jun 10 2011, 08:32PM
Xray wrote ...
Nah wrote ...
Yes, seriously, we need to know more.
To begin with, technically, is it a 10kV voltage source or a 23 mA current source? Can't be both.
Perhaps you are talking about a NST with "10KV" and "23MA" on the nameplate. An electrical circuit model for that is neither a voltage source nor a current source.
radiotech
Sat Jun 11 2011, 05:14AM
Google Barkhausen effects in type S1 fillament lamps,
to see why geometry is an issue.
Also, although you wont find it, more than 100 years ago, lightbulbs
were investigated because thermal characteristics were found to be
producing reactance-like effects.
Light bulbs are complex and , are terrible noise sources,
and cannot be easily modeled. The can produce sound, and act as microphones.
The filler gas is used to cool the filament, and without it the
tungsten would evaporate and blacken the bulb.
The filament can pull metallic ions through the glass
of a lighted lamp and cause them to coat the inner surface of the lamp.
Nah
Sat Jun 11 2011, 06:28PM
Radiotech,
Isn't that just the Edison effect?
If I remember correctly, Edision found that electrons were bombarding the inner surface of the bulb, carrying carbon with it. This was the genisis of the vacuum tube. Or are you taking about something different?
Guys, I am a pratical man. When I talk about a 10kilovolt, 23 miliamp voltage source, I am taking about a power supply (In this case a 60hz transformer) that outputs 10 kilovolts at a max of 23 miliamps. I understand that that may be a little confusing, and I apologize for that.
Please, ask any questions you like and I will look up the Barkhausen effect. It looks to be very interesting from a quick glance of it.
Sat Jun 11 2011, 08:00PM
Nah wrote ...
I'm practically interested in trying to duplicate your experiment, which is the reason for asking about particulars. Not trying to be pedantic.
Are we talking about a 60 Hz neon sign transformer with 10kV 23mA on the nameplate,
or "a power supply that outputs 10 kilovolts at a max of 23 miliamps"?
Ordinary NST's can never deliver their rated voltage at their rated current (their nameplates are weird about that).
The rated voltage is for an open circuit. The rated current is that at which the output voltage has dropped to zero (short circuit case). Intermediate currents give intermediate voltage reduction; normal lighted neon signs are much closer to the short-circuit than the open circuit.
