  • Guests: 57
Poll- Who owns a tube tester
Wed Apr 27 2011, 09:20PM
He's obviously not a guitarist, they turn it up till it explodes, then kick it around the stage.
A tube tester would certainly be nice to own, but they're not compulsory, I've built four tube amps and restored a radio without one. All the bad tubes I found were obviously bad, either weak, noisy, too much hum, or in the case of power tubes, clouds of glowing gas and complete fuse-blowing breakdown.
Beware of the cheap emission testers, they often connect all electrodes except the cathode, and use them as the anode. This can damage the tubes with excessive current. If you want a tube tester, get a proper one that can measure mutual conductance, like the Avo, Hickock etc. There is one very good Russian one with regulated DC supplies, but I can't remember the name.
Nah
Wed Apr 27 2011, 10:25PM
I've never payed more than $30 for a tube tester.
Clears up any info about tube testers.
Also, my favorite quote:
"To convince themselves that owning such a tube tester was no big deal, many old time tube technicians began believing that the only 'real' test was tube substitution."
What if you don't have a radio that uses that tube? What if it works fine in one set, but bad in another? 12AX7s arn't everything, you know. The real king is the 45!
radiotech
Thu Apr 28 2011, 11:10PM
This is my Avo universal. The data book is 17th ed. Simple circuit , Ha!
1304032253 2463 FT114231 Avo
1304032253 2463 FT114231 Avoschalpan
Nah
Fri Apr 29 2011, 12:01AM
What kind of pentode does it use?
testtest
Fri Apr 29 2011, 03:00AM
testtest Registered Member #3271 Joined: Mon Oct 04 2010, 02:29AM
I have two. One (Stark, Toronto) for vintage tubes from the 30s and a Mercury model 1101 (looks identical to the Eico model) that I used during the 50-70s for both TV and radio. Can post pix if you want.
radiotech
Fri Apr 29 2011, 03:58AM
the Avo Valve Characteristic Meter Mk. III uses two D 77 duo
diodes. The pentode depicts typical electrode selection.
Nah
Fri Apr 29 2011, 06:58PM
Cool!
looks great for something so simple.
Thu May 05 2011, 11:21AM
I built this several years ago. It is one of two 211/845 testers that allow both current and transconductance measurements.
