  • Guests: 40
CT2 (37)
Josh Johnson (46)
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
CW multiplier current limiting?
Newton Brawn
Tue Mar 29 2011, 02:08PM
Hi Daniel !
Is it possible to attache a complete schematic to better understand the situation ?
Regards
Newton
Dr. ISOTOP
Tue Mar 29 2011, 03:33PM
A 25 stage CW will have tremendous Vdrop under load.
Vdrop=I/(F*c)*2/3*n^3
Vdrop=1e-3/(1e4*1e-9) *2/3*25^3.
This has order of magnitude 100*25^3=1562500=approx 1e6 volts.
Wed Mar 30 2011, 01:52PM
Daniel Uhrenholt Registered Member #125 Joined: Fri Feb 10 2006, 01:52PM
This is a full wave multiplier, and with the stages I'm running the V drop should be around 50kV.
The caps has arrived today, and I'm on my way to the postoffice right now to pick them up:-)
This project have to wait a bit, as my former girlfriend is moving out of the apartment. So I have enough to do the next month or so... But that's okay, as I don't have to feel guilty of being a geek all the time:-)
I will start a project thread when I start the build.
Cheers, Daniel
Cheers, Daniel
Dr. ISOTOP
Wed Mar 30 2011, 02:09PM
What are your stages? Full wave doesn't change the vdrop much.
Wed Mar 30 2011, 02:33PM
Read it, and do a calculation on the calculator on the site. I will make 15 stages with 20kV input at 20khz and 1mA load. I have chosen a full wave because of the low ripple factor, and low drop under load.
I have a sphere for a big VDG that I purchased 1 month ago, it's one half of an 24*6" toroid with a half sphere on top, giving me a lot of capacity and voltage standoff. But I chosed to try out a multiplier instead, as I know that I can make the mechanical parts for a VDG with a belt width of 10", mechanical stuff is absolutely no problem for me!
Dr. ISOTOP
Wed Mar 30 2011, 05:32PM
OK, so you're not doing 25 stages; that makes sense.
Wed Mar 30 2011, 05:56PM
Daniel Uhrenholt wrote ...
Hi All,
I'm collecting parts for an 600kV CW multiplier at the moment..
What are you planning to use it for? What insulators will you be using?
This is in the right ballpark for proton-boron 11 fusion (optimum 630kV) if you have a vacuum system and some 'suitable' HV feedthroughs
Wed Mar 30 2011, 07:20PM
I build things for fun:-)
Really, I don't have a clue... That is the same thing about tesla coils, I build them for fun and to learn.
Ive always been impressed about high voltage DC, and I did build a really nasty VDG some time back. As I mentioned before I did have a plan about building a big VDG with a charging current of 320uA, but why not try to make something even more crazy?
I use a lot of time and money on my hobby, so why not push things a little further than every one else... smile
Cheers, Daniel
Wed Mar 30 2011, 08:49PM
Cheers, Daniel
Those 'nice people' over at fusor.net (Richard Hull, Carl Willis, Chris Bradley, etc.) swear blind that it's not possible for an amateur to build a 600+kV power supply. If you can do it, as I said before, you could be the first amateur to achieve aneutronic fusion (fusion without neutrons). I know someone who can get Boron 11, all you'd need apart from that would be some hydrogen, a means of ionising it (see my magnetron thread in 'electromagnetic radiation', or my earlier thread (I'll provide a link later)) and a vacuum system.
Wed Mar 30 2011, 09:03PM
My biggest Tesla coil had an estimated output of about 600kV peak amplitude. How much harder can it be to make a DC version? :^)
Somehow I think building a 600kV DC supply would be far and away the easiest part of a DIY aneutronic fusion reactor. (I'd start by stealing a length of 400kV gas insulated substation Link2 to use as the chamber, hopefully the national grid would not miss it too much)
