  • Guests: 56
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
How small can a VTTC be?
first  6 7 8 9
Fri Jun 15 2007, 09:19AM
Yes, one important function of those chokes is to isolate the tubes from each other and prevent parasitic oscillations in a push-pull mode. By strapping the two plates together and then using a single choke, you're kind of missing the point.
ShawnLG
Wed Jun 27 2007, 07:13PM
Judging from all of these large VTTCs submitted, it looks like I am in the lead. The tube I am using is a 6BQ6GTB. It is being heated form a switcher using SMT components. This cuts down on size. Below are the pics of the switcher, fan patch and the HV tube board with interupter and EMI filter. The fan patch was added to boost the filament voltage to run the 12V fan under the SMPS. I could of added a 12 volt output in the switcher. I did not know I would need forced cooling during the design phase.
Dimentions:
4.5cm width
8cm length
14.5cm tall
Updated Video (5/9/08)
1182971583 286 FT11043 Vttc Smps Tranny
1182971583 286 FT11043 Vttc Smps Proto
1182971583 286 FT11043 Vttc Smps1
1182971583 286 FT11043 Vttc Smps2
1182971583 286 FT11043 Vttc Smps3
1182971583 286 FT11043 Vttc Fan Patch
1182971583 286 FT11043 Vttc Hvboard1
1182971583 286 FT11043 Vttc Hvboard2
1182971583 286 FT11043 Vttc Hvboard3
1182971583 286 FT11043 Vttc Unit
Wed Jun 27 2007, 07:41PM
I admire that SMPS more than whole coil. It looks likle a forward converter? What IC did you use?
And how in world did you manage to etch that board like that, by hand or whatever? I get tired quickly drawing boards of similar size in eagle suprised
And are you sure everything is OK with the SMPS? You shouldn't require a fan for few watts of output power. I ran my flyback converters at about 10W continuously with a small Dpak mosfet in free air with no heatsink at all.
Still freakingly awesome coil. I really doubt anyone will put that much effort into a mini VTTC...
Wed Jun 27 2007, 07:52PM
hey, no fair, you have more silicon that vacuum in that coil :p
In any case, that is a mighty fine SMPS you have there amazed
Although if it were me I would have ran the coil off 12v (so I could use a battery later) and then to keep the part count down used a simple unregulated royer for for b+/filament. Also, I can't imagine why you would need a fan, unless your power supply is horribly inefficient, you only need <10w out...
But more worrysome is your spark output, you should be able to get WAY more than that. Did you try tuning it at all?
ShawnLG
Wed Jun 27 2007, 08:22PM
"And are you sure everything is OK with the SMPS? You shouldn't require a fan for few watts of output power. I ran my flyback converters at about 10W continuously with a small Dpak mosfet in free air with no heatsink at all."
I do not know exacly why it is running hot. I scoped the gate output and the mosfet on time is very short when under load. I can only assume that there is huge peak currents during these pulses. Also I do not know if the transformer core can source this much power. On the other hand, my fets on my DRSSTC ran cool with more abuse. The SMPS does run cooler with the gate voltage driven up around 15v, but I would need to rewind the transformer to supply more voltage to the 3842 chip.
"But more worrysome is your spark output, you should be able to get WAY more than that. Did you try tuning it at all?"
I did get better spark output around 1cm when the coil was on the protoboard. Since the transfer to PC it does not run too well. I guss the tube likes stray inductance and capacitance.
Thu Jun 28 2007, 09:25AM
Your tiny coils never cease to amaze me Shawn, and I think you're in the lead now too.
Brett Miller
Mon Jul 02 2007, 01:41AM
Brett Miller Registered Member #593 Joined: Tue Mar 20 2007, 12:32AM
Shawn,
Excellent work on the mini VTTC and you are *definately* in the lead in my book.
I think the conservative contention that tube coils should be as solid state free as possible is ridiculous. We're building tesla coils here in 2007, for innovation, fun, learning, and sparks. The tube is just there to switch the power.....not to "sit there and be vintage". I build disruptive coils, tube coils, and solid state, and I love hybrid drives too. Removing "boat anchor" iron was the original boon of the OLTC topology, and half and full bridge SMPS based systems like the DRSSTC. However, we got the iron back with the Piranha, but I still like that since it showed a very failure resistant switching mechanism.
I love the SMPS supply! You should be able to tweak it for larger breakout and longer power arcs. The good thing about having a contest like this is the fact that people get creative and come up with great systems like Shawn's....coils that inspire future work.
So yeah, I'm not trying to hijack the thread by giving an opinion, but since it's on-topic I won't apologize. If this keeps dragging on (i.e. -- no deadline) I might build something, but I have so many projects planned for the near future, it will be difficult. In any case, Shawn and EDY19's coils are super cool.
-Brett
What I've been working on: Link2
Tue Jul 03 2007, 02:42PM
Vaxian Registered Member #635 Joined: Tue Apr 10 2007, 01:56AM
I'm impressed.
I'm on vacation in PA now, when I get back I'll start the trophy for the winner.
Has anyone decided a time limit?
Dan
Experimentonomen
Fri Aug 10 2007, 04:48PM
Hey ShawnLG! Wheres the primary ? Or is it base driven like a plasma tweeter ?
ShawnLG
Fri Aug 10 2007, 05:08PM
"Wheres the primary ?"
The primary and feedback coils are inside the secondary.
first  6 7 8 9
