  • Guests: 38
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
How small can a VTTC be?
Dr. Shark
Mon Jun 19 2006, 03:41PM
You are absolutely right in that there is a limit somewhere, and we cannot make a TC running at 1GHz smile But if you look at Richie Burnetts HFTC, 4MHz is perfectly possible, and he was running comfortably at 400W CW. The coil did not produce very long sparks, and I think the reason might be that is was driven SSTC-style rather than DR. With tubes it would be possible to run DR at those frequencys, because tubes can take more abuse current-wise.
I am not a tube-person myself, but I think there is a lot that could be done.
Mon Jun 19 2006, 04:13PM
You can easily make a VTTC running at 2.45GHz, by putting a quarter wave long piece of copper wire in a microwave. tongue If you want a bipolar "coil" then get a half wave of wire and bend it into a loop with the ends close together.
Jim
Mon Jun 19 2006, 08:40PM
Jim Dunce.
Registered Member #28 Joined: Fri Feb 03 2006, 03:29AM
Look on my really old hot-streamer page. I made a "vttc" out of a miniature pencil tube, and a small coil of wire. It ran at like 30mhz off a camera flash inverter, and could light up fluorescent tubes from a distance. Not enough power to break out, however.
EDY19
Tue Jun 20 2006, 01:42AM
Just made one with a 6SN7 (twin triode, 2.5W each) with the triodes in parallel, running off doubled 120VAC (~335V). I can get it to oscillate, and with a non grounded screwdriver on one end of a xenon strobe tube and the other end connected to the secondary, It lights up. I cant get breakout though. I made a feedback winding with more turns, and that helped a little, but still no breakout. Im using a 20k grid leak resistor, and a 2nF grid leak capacitor, and i've tried tank caps marked "390" and a 1nF one. Suggestions welcome if you want to see breakout smile
Dr. Shark
Tue Jun 20 2006, 10:05AM
Yup, my suggestion is still standing: Dont drive it as a classical VTTC, pulse it and make it a DRVTTC. hit it with some really high peak power, keeping the duty-cycle low. The key might be to have a primary circuit with a very low surge impedance, since tubes can take a lot more current than IGBTs.
This might be a heap of b***sh** since I have never been near a VTTC myself, but I really dont see why it should not be possible to build a DRTC with the switch, the primary and the tank cap all in series. Someone correct me if I'm wrong, otherwise I guess I have to buy a tube and try it smile
Tue Jun 20 2006, 11:15AM
It's not true that tubes can take more current than IGBTs. They usually run out of emission at an amp or two for big power tubes, and proportionately less for small tubes.
Dr. Shark
Tue Jun 20 2006, 12:18PM
Thanks for pointing that out. As I said, I am a tube-noob. Replacing the tube by a hydrogen thyratron would probably cure the problem, but would be getting uncomfortably close to an ordinary spark gap coil again. I think what I was getting at was a half-bridge of tubes, since DRSSTCs seem to work so well, and that requires being able to turn the switch off. I am not so sure if any tube-like devices exist that sustain high peak currents and have turn-off capabilities.
Tue Jun 20 2006, 08:33PM
I think there was something on pupman list about thyratrons, and they didn't work too well.
Good old, evil, noisy spark gap still seems to pwn in this kind of disruptive coils (not counting DRSSTC's as they are a bit different actually)
Dr. Drone
Wed Jun 21 2006, 04:45AM
shades
Desmogod
Wed Jun 21 2006, 06:49AM
Found this while looking at 811A coils.
