  • Guests: 49
01/04 bomberguy92 (34)
01/05 Timo (40)
01/06 Ash Small (63)
Flyback (collaboration) for Corona, Insulation, Waveform purposes.
Newton Brawn
Tue Mar 08 2011, 10:43AM
Hi Patric:
Thanks for tjhe 555 site.
Can you shou the complete schematic that you have in mind?
Regards
Tue Mar 08 2011, 11:48AM
Patrick wrote ...
Does anyone know how well acrylic resists surface carbon tracking? (relative to other plastics: good, fair, poor?)
Ionic surface contamination (e.g. fingerprints) and ionizable inclusions are the usual suspects in tracking failure, whichever dielectric is used.
But don't take my word for it! Google comparative tracking index and get your DIY lobotomy kit absolutely free of charge!
Tue Mar 08 2011, 08:28PM
Newton Brawn wrote ...
Hi Patric:
Regards
Yes after my calculus homework is done, i will put up the schematic.
Thu Mar 10 2011, 04:37AM
Schematic:
1299731849 2431 FT110121 555pwm
OK, everybody check my work, polarity and stuff. I was less than sober while putting this together. angry
First, on the 555 the pins 4 and 5 are left unconnected. I havent decided what to do with those yet.
Second, the TVS's are hopefully pointed right.
Third, R3 and R4 are pots, the R2 and C3 have not been fully decided yet.
Finnally, the Q1 device would be a common N-channel Mosfet ot IGBT.
So find my errors and make suggestions now before I commit to etch the board
Antonio
Thu Mar 10 2011, 01:03PM
D5 cannot be there. It will eliminate the necessary flyback pulse. The usual solution there is a fast diode from the drain to a parallel RC circuit connected to the power supply. A voltage limiter can be put in parallel with the RC circuit.
Thu Mar 10 2011, 03:15PM
Antonio wrote ...
D5 is a TVS invisible until in 600V, are you sure the flyback pulse will exceed 600 V , for a 10 turn primary? or do you mean it's hold off should be bidrictional?
Antonio
Thu Mar 10 2011, 04:24PM
Patrick wrote ...
Antonio wrote ...
The diode in this position will clip the pulse at the drain of the switching transistor at the power supply level, not at 600 V. A bidirectional device will work.
Thu Mar 10 2011, 05:19PM
OK, yeah i see your point, is this and improvement? 600v held off in either direction, before clipping.
1299777545 2431 FT110121 555pwm2
@antonio:
Antonio wrote ...
Can you show me an example? i fail to understand.
James
Thu Mar 10 2011, 08:15PM
Patrick wrote ...
@antonio:
Antonio wrote ...
Look up RCD snubber. There are lots of application notes out there. As power levels increase though the snubber can dissipate large amounts of energy. I tried once using a 60W incandescent lightbulb as the resistor and could easily light it full brightness with about 40V going into the circuit.
Antonio
Thu Mar 10 2011, 09:03PM
If the load is not constant and there is no feedback, it's better to use something that recycles the energy in the transformer primary if it is not used in the secondary.
This is a flyback circuit that I made some time ago with an RCD snubber:
The resistor R3 was eating a lot of power. This is a modified version that worked much better, with C3 and D3 returning unused energy to the power supply:
Don't look at the switching transistor driving circuit, that is very inefficient and has insufficient base current capability for that transistor.
