  • Guests: 53
Voltage booster
Michalis.Biochem
Fri Feb 25 2011, 08:19AM
Michalis.Biochem Registered Member #3340 Joined: Wed Oct 20 2010, 07:28PM
Ken M. wrote ...
For something like 300v or so I suggest using a boost converter a simple design will work fine follow the design like this Link2 , which includes a calculator to figure up the part values you need for desired supply and output parameters.
Thank you smile
I think pusled dc can drive the cw voltage multiplier. I have done it with a disposable camera board before.
Adam Munich
Fri Feb 25 2011, 03:31PM
Michalis.Biochem wrote ...
Unless vou're pulsing both negative and positive dc it's not happening.
Voltage Amplifier Explain
Dr. ISOTOP
Fri Feb 25 2011, 03:43PM
And unless the frequency of the AC is very high, and the CW is very well constructed, you're not going to be able to draw appreciable currents from the CW.
Michalis.Biochem
Fri Feb 25 2011, 07:50PM
I made this driver. It is powered by a 9v battery. It driver a small xformer(walwart). What i noticed using the multimeter was that the xformer was giving both ac and dc. How is that possible?
James
Sun Feb 27 2011, 11:01PM
Multimeters can interpret ripple on a DC supply as AC voltage, and if you try to measure AC voltage with the meter set to DC it will give confusing readings.
A ZVS driver will run on 6V if you use mosfets with a suitably low gate saturation voltage. You could also build a Royer oscillator using bipolar transistors. If you want more voltage you can always connect two 6V batteries in series too.
