  • Guests: 52
Can you use a microwave transformer fora small Tesla coil?
CokeCanNinja
Tue Feb 22 2011, 11:31PM Print
CokeCanNinja Registered Member #3706 Joined: Mon Feb 21 2011, 04:17AM
I'm starting to design my first Tesla coil (a spark gap design) and I was wondering if I could use a microwave transformer instead of a NST. The coil will only be ~1 foot high and doesn't need to that powerful, I just want to build a coil to do some tricks with. I can get a microwave for free and rip out the transformer, but for a NST I'd have to shell out at least ~$75.
Dr. ISOTOP
Wed Feb 23 2011, 03:01AM
MOTs are dangerous, high current, and low voltage. They're usually used for big coils, and even then only with shenanigans like DC resonant charging.
teravolt
Wed Feb 23 2011, 04:32AM
hi CokeCanNinja the answer is yes but the spark gap has to be deigned for the low voltage of 2100 vac. another option is 2 microwave oven transformers out of phase for 4200vac. They have to be exactly the same so they share the power evenly. Building this won't be easy or straight forward. The Kind of capacitors you use will have to get are polypropylene or pulse types of capacitors. I have seen pictures of 4mot teslas with 5ft sparks. CokeCanNinja these types of transformers are not toys and can be lethal when not respected or any high voltage so be mindful of what you do before you do it
CokeCanNinja
Wed Feb 23 2011, 06:51PM
Oh well, I just I'll just plunk down some cash for NST.
DerStrom8
Wed Feb 23 2011, 08:24PM
DerStrom8 Registered Member #3704 Joined: Sun Feb 20 2011, 01:13PM
CokeCanNinja wrote ...
Before you do that, perhaps you can ask a local neon sign shop for old NSTs? That's what I did several years ago, and they ended up having two that they just wanted to get rid of. I just got them for free. I'm not sure if you have a local neon sign shop, but if you do, it is worth giving it a try.
Good luck!
Der Strom
Thu Feb 24 2011, 05:43AM
A single MOT can get decent sparks with a voltage quadrupler and a charging choke. I made this after reading about Steve Conner's single MOT sgtc Link2 Use a higher capacitance tank cap and lower BPS for longer arcs.
teravolt
Sat Feb 26 2011, 04:39AM
mots are a better choice because they are cheaper and easier to to find and lighter. Do you have a ebay account and what is your budget like? neons will need caps of a higher voltage but the of the same type. When I started out I made some caps out of sheeted glass and aluminium foil with a mixture of oil and perifin for insulator bewean each sheet of glass. poly caps will offer waight reduction and no mess at about 2.5ea. the forum has lots of examples of things poeple have done. what do you have in mind.
Dr. Slack
Sat Feb 26 2011, 09:16AM
NST versus MOT?
For a first spark gap coil, NST every time.
It's a first coil, so keep it simple. Higher voltage means more tolerant spark gap design. A MOT's 2kV is right on the ragged edge of what's possible, very touchy gap control, changes fast with erosion, you have a lot more freedom north of 10kV.
You *can* multiply a single MOT up to the same sort of voltage, but then it's more complexity, and DC. It's possible in theory to get a fixed spark gap working with DC resonant charging, but it's much better, more reliable, safer with a rotary spark gap, which is yet more complexity. Once you've had a fair bit of ozone in your nostrils, then RSG with DC resonant makes a very controllable, powerful and satisfying spark coil, but not for a first.
You *can*use multiple MOTs to stay AC, but then it gets heavy real fast as you add more MOTs, they're not realy insulated for the voltage you're stacking them for, so you probably need to put them under oil. It's not the way to do it, first coil or not.
As an aside, if you get bitten by an NST's 30mA or 60mA, you'll probably live. Get bitten by a MOT's 1amp and you'll probably die.
aris
Fri Jul 05 2013, 06:27PM
aris Registered Member #2871 Joined: Sat May 22 2010, 06:50PM
hey guys i need some help about 4 mot stuck for my power supply of a big tesla coil.I use as ballast a fifth mot but this drops my output voltage too much....What can i use to ballast the quad mot stuck?
Fri Jul 05 2013, 07:10PM
MOTs are low voltage - usually about 2100-2400V. They are also not internally current limited, so they will require a ballast.
2.1kV-2.4kV is NOT good for a spark gap coil. Too much current in the tank circuit / spark gaps to be efficient.
Franceformer used to make really nice 4kV, 20mA NSTs which were perfect for table-top coils. Not sure if they are still available, but they were great!
