  • Guests: 67
Tasks such as this should not be attempted by man.
first  2 3 4 5
Microwatt
Tue Feb 22 2011, 10:52PM
Do you think that having fewer windings per pancake would solve the capacitance issue?
Wolfram
Wed Feb 23 2011, 07:35AM
Microwatt, it would lower the capacitance somewhat, but it would still be far from practical, maybe even impossible, to make a transformer with 3000 secondary turns work at 80kHz. I think the best way of winding HV secondaries for high frequencies is the Steve Ward single-layer method Link2 .
Grenadier, I think a multiplier is the best approach. Maybe you could take some inspiration from the original transformer that used to be on your multiplier board:
1298446502 33 FT108894 Dsc 4960
Adam Munich
Wed Feb 23 2011, 07:46AM
Actually I tried using my 1940s AC flyback and I've been getting really loud sparks out of the multiplier, loud enough that I need earmuffs. I've heard 1mA sparks from an iron cored xrt before and I think I'm getting about 1mA, though I'm not sure how its happening at 30khz...
(yes, I have a 15 meg resistor on the output, so the diodes are safe)
Also, what are the chances that i'd see another multiplier like that? neutral
Wolfram
Thu Feb 24 2011, 12:25PM
Grenadier wrote ...
Surprisingly high. Do you know where the board you have came from?
Adam Munich
Thu Feb 24 2011, 06:01PM
I do not.
Also, do you know the ratings of its diodes?
first  2 3 4 5
