  • Guests: 44
100 micron Vacuum drying dielectric oil...
Tue Feb 01 2011, 09:40PM
its times like these when 4HV saves me from so much trouble.
As per Mattski's point I will make a steel water pipe vacuum vessel, 2 in OD laying on its side, half filled and 3 feet long. If half filled with vaccuum and half filled with oil it will have greater surface area then just a cylinder's circlular area standing on end. this would speed up and increase the drying effciency at the expense of pulling a vac on much greater volume.
as Ash has said, a rotary vane pump is what I will use.
I geuss flexible tubing is out of the question, so the pump and vessel must be held together with rigid pipe, and supported carefully? Flexible steel braided rubber flex pipes are tempting, but I presume I can kiss 100 microns good bye if I use such a tube?
GluD
Tue Feb 01 2011, 09:45PM
GluD Registered Member #1221 Joined: Wed Jan 09 2008, 06:17PM
The greater volume shouldnt be a concern I think. My two stage rotary vane pump can pull out 70 liters per minute. At least it says so on the paper.
Tue Feb 01 2011, 09:50PM
GluD wrote ...
Yes but with my previous experience the harder the vacuum, the longer it takes. Just based on the fact you and I depend on piston/rotary vane pumps, which are inherently limited (due to kinetics ), versus turbo-molecular pumps.
Tue Feb 01 2011, 09:51PM
Patrick wrote ...
.I geuss flexible tubing is out of the question, so the pump and vessel must be held together with rigid pipe, and supported carefully? Flexible steel braided rubber flex pipes are tempting, but I presume I can kiss 100 microns good bye if I use such a tube?
Flexible re-inforced tubing is often used for forelines (rotary vane pumps), so don't rule this option out just yet.
Tue Feb 01 2011, 09:53PM
Ash Small wrote ...
I f I could get away with this it would save me from such headaches and trouble!
Carl Pugh wrote ...
One thing that you might be careful of is that
Oil that has all the dissolved air removed has a high breakdown voltage.
Oil that does not have any of the air removed has a high breakdown voltage.
Oil that has some of the air removed has a much lower breakdown voltage.
Can anyone back up Carl Pugh's thoughts here?
Tue Feb 01 2011, 11:32PM
Patrick wrote ...
Ash Small wrote ...
I don't see why not. Here's a report I'm personally familiar with, showing vacuum of 50 microns readily achieved in a gallon-size vessel using rotary vane pump and ordinary flex tubing (not spiral reinforced vacuum hose). Link2
Your horizontal pipe idea is good, not only to maximize the oil surface area but to minimize its depth. If half full of oil, the hydrostatic pressure at the bottom will be about 2000 microns, even if pipe is pumped to a perfect vacuum.
You're right that heating the oil while under vacuum will speed up the drying and degassing. I have thought about drying my oil in small batches in a metal pan, that could sit inside the vacuum pot and be separately heated. (when in doubt I tend to be over-conservative, rather than try the fast way and improve if necessary).
Carl told me that in commercial practice, oil is often admitted to an evacuated transformer tank through a spray nozzle in the top, giving dissolved moisture and air a good final chance to escape. In a vacuum pot you could even circulate the oil mechanically with an external pump, drawing it out from the bottom and spraying it back in from the top.
Patrick wrote ...
Carl Pugh wrote ...
Sounds plausible. What matters to you is not whether your oil's breakdown voltage is maximized, it's whether it meets your absolute requirement. Why not make a dielectric-strength test cell with gap (between slightly convex electrodes) small enough to test with a NST?
Tue Feb 01 2011, 11:52PM
Klugesmith wrote ...
Your horizontal pipe idea is good, not only to maximize the oil surface area but to minimize its depth. If half full of oil, the deepest fluid will have an absolute pressure of 2000 microns due to weight of overlying oil, even if pipe is pumped to a perfect vacuum.
Yes, these two facotors length for SA, and shallow depth, were why I thought steel pipe idea up. The wheight of overhead oil, I had not considered. Now the pipe is steel thick wall, 1.4 ID, half full will have 0.7 inches of oil at the deepest,the pipe would then be as long as needed for a useful volume for each run.
You're right that heating the oil while under vacuum will speed up the drying and degassing, but that would greatly reduce the strength of PVC pipe if that's what you're planning to use.
Its going to be threaded, sealed thick wall steel pipe now, not plastic, and later i can choose too heat it, externally, which eliminates the need for wires to pierce the vacuum vessel.
Spray nozzel, if this works maybe others can pursue that idea.
An Acrylic + two 1" balll bearings sumbmerged in oil energized by a Variac+NST with HV voltmeter has already been built, for this project. Quality control matters.
Klugesmith, is that source you cite, just using common tubing from the hardware store?
James
Wed Feb 02 2011, 05:07PM
The vacuum bible:
Wed Feb 02 2011, 06:09PM
James wrote ...
The vacuum bible:
Ooooooo! Sams faqs are great i shouldhave been smart enough to check this on my own suprised
Xray
Wed Feb 02 2011, 08:16PM
Patrick wrote ...
James wrote ...
The vacuum bible:
Patrick - I've been degassing dielectric oil for X-ray tube heads for about 12 years, and I'd be happy to tell you about my vacuum system and process that I use. I use a very large glass bell-jar (with safty cage) and a Welch model 1397 2-stage vacuum pump. A diffusion pump is not necessay.
Later today I'll post a picture of my vacuum system, and I'll give you some details about te process that I use for degassing. Right now I can't spend any time on 4hv because of my huge backlog of work that's been piling up. But I will get back here later this evening (Minnesota time).
Later.....
