  • Guests: 39
RG8/U cable for 60 kv?
radiotech
Sun Feb 20 2011, 03:37AM
There are a few hugh capacitors here, stand about 2 feet high
12 inches on the side, and are in plexiglass cases.
The cables look RG8ish, and even had PL259 connectors for
22 kV or so.
However, the PL259 plugs had no contact assembly, and only the
shell was used to ground the shield to the wiring common inside. The center poly wire went straight though plug and body over to
the capacitor terminal where the insulation was penciled down over about two inches back to the full diameter.
Pencilling is an electrical term meaning form a cone.
Sun Feb 20 2011, 04:38AM
radiotech wrote ...
22 kV or so.
Where is "here" ?
